Need help with a weird lighting issue
Discussion in 'Ask An Owner Operator' started by Antonovich, Sep 16, 2020.
  1. Antonovich
    Antonovich Light Load Member
    143
    96
    May 11, 2019
    So it looks like mine are either reversible or I got lucky and installed correctly because they do work. My issue is about trailer lights getting stuck on, not truck lights.
  2. GreenPete359
    GreenPete359 Road Train Member
    2,273
    5,469
    Oct 21, 2017
    Driving my recliner
    Open your pigtail up & check to make sure all the connections inside of it are tight.
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    My dash indicator was also on. If I disconnected the trailer. Then the truck worked fine.
  4. Heavyd
    Heavyd Road Train Member
    7,831
    6,282
    Feb 4, 2009
    The trailer signal feed and turn indicator share the same power source from the trailer turn relays. The trailer left and right turn have their own relays but the relays are controlled by the flasher. So either you have the wrong style of flasher and enough power is going through to keep the lights on, or the trailer lights are back feeding somehow. If you remove the trailer turn relay and indicator stays on, this means the trailer is backfeeding somewhere. If not, I would say your flasher isn't compatible.
    Antonovich, daf105paccar and 062 Thank this.
  5. Antonovich
    143
    96
    May 11, 2019
    But that's the thing, my dash indicators stay on regardless if I have a trailer or not. Though my turn signals still work as they should on the truck.
    uncleal13 Thanks this.
  6. nerd_sniped
    nerd_sniped Bobtail Member
    Sep 17, 2020
    http://bodybuilder.navistar.com/General/Documents/svcmanpdf/0000011981.pdf
    The dash indicator and trailer are driven by the turn relay (red circle) the lamps on the tractor (green circle) are driven directly by the flasher.
    CEC Industries, LTD. Your Global Partner In Lighting Solutions
    It sounds to me like your flasher isn't rated for low enough currents. A single LED stop lamp could be as low as the 0.1A range.
    If you unplug the stop lamp on the tractor (simulating a burnt-out bulb), see if the indicator on the dash behaves the same way. If so, it is a pretty good bet that the flasher is designed to indicate a lamp failure by latching on. The flasher thinks your low current LED is a failed lamp.
    speedyk and daf105paccar Thank this.
  7. Antonovich
    143
    96
    May 11, 2019
    Imgur: The magic of the Internet
    I noticed the turn relays are different. Left is 50A, right is 40A. When I turn on my 4-way flashers I've noticed the right dash indicator would flash a little bit. It still hangs on longer than normal, but it does flash. However, right turn signal it doesn't flash.
    I also tried another flasher, CEC 45A, same thing.
  8. nerd_sniped
    Sep 17, 2020
    The 50A vs 40A difference in the relays has to do with the output level that the relays can handle. I wouldn't be surprised to see your 4-ways work even if the regular turn doesn't. Two lamps...double the current. What turn lamps are you using?
  9. Antonovich
    143
    96
    May 11, 2019
    LED's are Yorkim 3157
    After playing around with different combinations, I noticed that the 2 front turn signals are the cause. I went and bought regular 3157 bulbs. The 2 side turn signals are not affected by LED's and still work just fine. The dash signals also flash correctly. However, if I unplug a regular bulb from the front turn signal, or if I switch to LED bulb in the front, that's when I get the stuck dash signal. So, a short or bad wire / connection on the front signal harness?
    EDIT: you know what, whatever. I found the culprit. I just switched back to regular bulbs up front. Will leave the side and rear LED. Seems to be working normally. Will test out with a trailer when I get a load. If all goes well then I guess I can't have LED turn signals up front.
  10. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    Did you try the LED's with the polarity reversed?
