Need help with a weird lighting issue
Discussion in 'Ask An Owner Operator' started by Antonovich, Sep 16, 2020.
  1. Antonovich
    Antonovich Light Load Member
    143
    96
    May 11, 2019
    Yes, I flipped them around, cleaned the connector socket, makes no difference - they work but my dash signal gets stuck on, so in turn I'm guessing the trailer lights would also get stuck on.
    daf105paccar Thanks this.
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Do they work if you put both the LED and the bulb?
  4. Antonovich
    143
    96
    May 11, 2019
    Tried it. The lights both flash as normal but the LED side gets the stuck dash indicator.
  5. nerd_sniped
    nerd_sniped Bobtail Member
    Sep 17, 2020
    Did you try LEDs in front and regular lamps in the rear?
    I hate to sound like a broken record, but this still sounds like a low current / flasher issue. The fact that having the LED lamp and having a missing bulb up front produces the same behavior indicates this.
    Here is a super common work around for this problem: https://www.amazon.com/Yorkim-Resistors-Festoon-Message-Cancellor/dp/B07KS6KMYG
    The kit is a four pack...but...it sounds like you may only need a pair for your front lamps. Doing this would negate the efficiency improvement of LED on your system (the load resistors work because they draw as much current as an incandescent)...but shouldn't affect the life of the LED bulb. The other thing to think about is sealing. A cut splice like this is a new potential failure point for your harness. However you seal it...seal it like you mean it. LOL
    Antonovich Thanks this.
