Need help with AC fix.
Discussion in 'Volvo Forum' started by Snailexpress, May 14, 2016.
  1. flood
    flood Road Train Member
    4,169
    4,050
    Dec 25, 2010
    Any codes in the climate unit. Under fault diagnostics
  3. UltraZero
    UltraZero Medium Load Member
    406
    96
    Jul 18, 2013
    None.. is it possible to have more then a little enough to trigger the low side, but, not enough to create pressure to trigger the hi side??
    Hmmm... Things that make you go hmmmm..
  4. flood
    4,169
    4,050
    Dec 25, 2010
    This will sound stupid but volvo changed the ac compressor a few years ago. The new ones have the same plug as the old ones BUT you must plug in a adapter resistor then plug it into the truck. For it to work.
    KB3MMX and Snailexpress Thank this.
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    post a picture of what kind of compressor you have if it's the new type of compressor they have been going to you need jumper harness or switch the wires in the connector for it to work. did you by any chance have compressor replaced if not check to see that you have power and ground at the copressor and then go fromt there if no power make sure everything is working properly with climate control maybe need to replace it.
    flood Thanks this.
  6. UltraZero
    406
    96
    Jul 18, 2013
    Can you post a pic of what you are talking about. This is a new one.
  7. Snailexpress
    2,675
    6,069
    Apr 28, 2014
    Rocky
    Thank all for help \. Problem is solved.
    ######## Volvo blow my mind changing the switch lighting . now if AC is OFF switch light is ON
    KB3MMX Thanks this.
  8. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    There is a lot of different controls for it depends on what you have
  9. UltraZero
    406
    96
    Jul 18, 2013
    hmm. that doesn't sound right. Sounds like a programming issue.:confused:
    Arizona anyone?? 115 today and my AC doesn't work. Whewww..:eek::eek::eek::eek::eek:
  10. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,596
    Dec 29, 2014
    Orrstown, PA
    Dear God!!!
  11. UltraZero
    406
    96
    Jul 18, 2013
    Soo. 108 today. If the Low pressure sensor on the truck stuck meaning it's reading that here is pressure in the system, won't this allow the a/c compressor to always stay on??? Also, since there isn't any pressure in the system, the Hi pressure sensor will not activate to shut the compressor off. Does this sound right?? Need to find the leak, install new low pressure sensor, leak test /recharge..
