Need help with air system.
Discussion in 'Volvo Forum' started by Socal Xpress, May 6, 2018.
  1. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    2010 630 982k D13 10speed
    This is a intermittent problem. The truck will air up and cut out ar 120psi but the rear airbags wont air up. Also the HI/Low wont engage or the 5th wheel slider engage.
    I installed a new govenor a month ago and had been trouble free until this morning. Swapped out to another brand new governor and got everything to air up again but one of the fittings was leaking badly. I reinstalled the older govenor and everything worked normally again. What is going on?
    @nasriza
    @QUALITYTRUCK
    Thanks
  3. boneebone
    boneebone Road Train Member
    2,297
    2,372
    Mar 13, 2009
    Have you serviced/ replaced your air dryer cartridge lately?
  4. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    I replaced the whole unit before this past winter. (rebuilt dryer with new cartridge.)
  5. Working2party
    Working2party Medium Load Member
    608
    729
    Feb 10, 2018
    Kansas
    Not sure what your working on... but normally the transmission range, suspension (cab, seat, axles), cab accessories ( air horn, vents, etc), and exacts air supplies run off the secondary air tank, but because they aren’t considered priority they are run off a pressure /check regulator that opens anywhere from 60-90 psi depending on the truck. On freightliners this is usually a Christmas tree looking fitting that has multiple air lines coming out of it mounted on the secondary air tank. If 2 or more minor systems are inoperative, it’s usually because one or more of these valves sticks. On freightliners, there is a button on the end of the valve that pops out when the PSI is met, if you in a bind and can find it, tap on it, or “help” the button pop out.
    Hope this helps.
    magoo68 and Socal Xpress Thank this.
  6. Benek
    Benek Light Load Member
    83
    39
    Feb 10, 2016
    Had this problem last year, with the exception that all drives air bags did not aired up. Ended up changing leveling valve. That fixed it. Before changing valve I used to drop the trailer and drove away from trailer and slammed on the brakes couple of times, a quick fix before I fixed properly
    Socal Xpress Thanks this.
  7. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    the only thing all these problems have in common is that they come from the secondary tank all of the air supplies, i would check the check valves in your tanks to make sure that they are not getting stuck also check for major air leaks, you have a side manifold on the chassis its called a safety manifold and the trans and everything you are mentioning feed from there so that would also be a good place to start, driver side of frame by the transmission,
    Socal Xpress and QUALITYTRUCK Thank this.
  8. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    So I changed 2 check valves and the safety manifold. Still not getting air to the accessories. This is a head scratcher.
  9. nasriza
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Pull the hose from the manifold where the solenoids go and chase the problem from there or feed it with a separate line tin off from the secondary tank not proper but it will work
  10. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Update. The check valve I bought from the dealer was not the right one. Had just a regular fitting installed and now all
    accessories are functioning properly.
    Thanks @nasriza
