Need help with build options for c15 475 Acert
Discussion in 'Trucks [ Eighteen Wheelers ]' started by scorpiorias, Jul 19, 2014.
Thread Status:
Not open for further replies.
  1. scorpiorias
    scorpiorias Light Load Member
    106
    43
    Oct 25, 2009
    Philadelphia, PA
    I have a grossly under powered and headache 475hp c15 acert, done quite a bit of research into the difference between factory 625hp and 475hp. With everyone and their mama pointing out the obvious; bigger cam, pistons, injector and turbo; without any part numbers and most importantly, what it entails to make that leap, its quite a runaround for some of us looking to upgrade. And the cat house wont divulge any part numbers until I give them a serial number from a true 625hp. Any body knows the part numbers of a 625hp internals. How much bigger is the piston, does it need to honed and by how much. Had incredibly high blow-by, oil coming out of the breather, installed a kit from cat to no avail. massive oil leak from the back end of the cylinder gasket, dismal fuel mileage and salt to the injury, fan clutch cuts a groove through the radiator from wobbling too much. This a wreck on an engine and I had enough. Time for a build! With the head off and boy it is a mess to say the least, I supposed I should do all upgrades within my reach. Anyone had experience with IPD parts? I plan to source my parts from them. I mostly work on aircraft engines and this is somewhat different rather than new to me. So any Ideas will be greatly appreciated.
  3. bgxpress2006
    bgxpress2006 Light Load Member
    248
    73
    May 25, 2013
    Montreal, Quebec
    pistons are not bigger, they are lower compression, injectors are bigger, turbos have larger housing, your 475 can be turned up to 550 and with the proper trim codes will definately put a smile on your face, if you want more get a pdi tune or a Bullydog...result will be non stop ear to ear smile,
    J.S. Thanks this.
  4. bgxpress2006
    248
    73
    May 25, 2013
    Montreal, Quebec
    wowi simply said pdi and BD and post is not showing up
  5. bgxpress2006
    248
    73
    May 25, 2013
    Montreal, Quebec
    625's dont have bigger pistons they have lower compression pistons for the added boost the 625 generates, the turbo housings are larger and the injectors are bigger, not sure about the cam, as forpiston size the bore is the same
  6. scorpiorias
    106
    43
    Oct 25, 2009
    Philadelphia, PA
    thanks bgxpress, You are right, I just did a side by side comparison of the two, same bore, stroke and all but different compression ratio....I assume the 625 piston is more concaved inward than the 425. I am very aware of the software tunes and their limitations as well. as a matter of fact I had mine uprated to 550 and it barely did a thing to it. I figured since i have this thing torn I rather make some upgrades to the hardware. I have a PDI cam and manifold, I am hoping to have their tune after I am done putting this thing together. if you got access to the part numbers, please let me know.
  7. bgxpress2006
    248
    73
    May 25, 2013
    Montreal, Quebec
    That I dont have. Just use the serial # of a truck with a 625
  8. bgxpress2006
    248
    73
    May 25, 2013
    Montreal, Quebec
    In the CAT parts listing the 625 is called king of the hill, a good shop will easily find those parts you need
  9. IH Branded
    IH Branded Medium Load Member
    412
    104
    Jun 4, 2013
    Great Lakes area
    Yeah what he said. The bullydog is something tangible you can hold in your hand and sell or move to the next truck. If you find a really really good dealer you will be just as happy as a PDI tune that you could loose and never be able to resell.
  10. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    Here's the disclaimer you have to sign if you want a PDI...
    That disclaimer speaks for itself. TTR is not here to promote items that are consider illegal on the public highways. I'm pretty sure the admin made his point clear on this topic. Please take that somewhere else as TTR does not endorse either product.
    One of these days in the near future the EPA is going to crack down on this stuff. First they will go straight to the source and anyone that advertises it. We would hate to have the forum shut down over a very small percentage of posts.
    There's a reason for that. If you take the time to read the docked threads on top of each forum you would know.
    http://www.thetruckersreport.com/tr...ion-modification-deletion-threads-please.html
  11. skateboardman
    skateboardman Road Train Member
    6,232
    5,707
    Jan 14, 2012
    flatbed heaven
    condo, I think you are a bit off with this. you can easily get a pdi tune or a bully dog tuner which in no way modifies the emissions system. the tunes can simply change the horsepower parameters , and settings for speed rpm etc.
    you are sweeping with to broad a broom. not all tunes are designed for emissions modification, they are exactly what they say a tune of the existing parameters without removing or changins any of the emissions systems.
    Ukumfe Thanks this.
  • Thread Status:
