Need help with CB in truck.
Discussion in 'CB Radio Forum' started by AF461, Apr 28, 2011.
  1. AF461
    AF461 Medium Load Member
    380
    167
    Oct 7, 2010
    Dover, DE
    I have a Galaxy DX 959. I put it in my truck and I keep getting feedback off the stereo speakers. I'm in an 07 Peterbilt and the it is pre wired from the factory for CB's. Not sure how to cure this.... Can anyone help me figure this out?
  3. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    so the CB is coming back through the stereo speakers in your truck? I wonder if this is a grounding issue or if you're throwing too hot of a signal... I've never run into that... then again, I never run my stereo and CB radio at the same time.
  4. AF461
    380
    167
    Oct 7, 2010
    Dover, DE
    Even with the stereo off it still comes through the speakers. I do have a 75W kicker installed on the back of the radio.... Not sure if that makes a differance.
  5. SHO-TYME
    SHO-TYME Road Train Member
    3,425
    3,180
    Apr 20, 2011
    Dahlonega, GA
    Is the CB mounted next to the stereo, if so, the signal will jump across to your stereo speakers because of the power produced.
  6. Smaggs
    Smaggs Pie Crust
    1,405
    698
    Apr 12, 2011
    Pittsburgh, PA
    So you have an amplifier for your CB transmit? If so, THAT is your issue. I had one on a base station and it would come through speakers and my neighbor's television sets. Needless to say, I took the amp out of the mix.
