Need help with Cummins code
Discussion in 'Freightliner Forum' started by jbatmick, Feb 15, 2015.
  1. jbatmick
    jbatmick Road Train Member
    2,200
    2,511
    Dec 1, 2009
    hastings, Fl
    2001 F/Liner, N-14 Cummins, 850,000 ,miles. 370 hp.
    Yellow ' check engine ' light started coming on for a few seconds at a time about 3 weeks ago. Then started staying on a little longer, maybe up to 3 minutes. Might not come on for 2 hours, then will come on.Might go right back off, may stay lit 5 minutes. No regular schedule. Does it sometimes at start up. sometimes at running temperature. If I turn off engine while going down the road, then turn it back on, yellow will go out.:dontknow:
    Every once in a while the red light will begin flashing after the yellow has been on a while, then will stop after 2 to 10 flashes. Engine has never de-rated, always runs fine.
    Replaced the low level water sensor, as that had given me trouble several years ago.Removed battery cables, computer re-set. Worked fine for a while. then back to flashing yellow every so often.
    The only code it shows is 4 short red-space-1 red, 1 yellow, then 1 red. I cannot find that code:scratch:.
    Any thoughts ?
  3. 062
    062 Road Train Member
    6,346
    34,009
    Oct 20, 2013
    Bumping it up. May have to find someone with a reader,or insite. All flash codes I've seen are three digit the yellow would be space between codes. Did you check fuse holder at batt. For corrosion
  4. jbatmick
    2,200
    2,511
    Dec 1, 2009
    hastings, Fl
    Thanks, I will check the fuse holder. Still running fine, came on twice today, 1 time about a minute, then later for 15 seconds.
  5. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    111 Electronic Control Module ECM Microprocessor
    115 Engine Position Sensor EPS Circuit
    121 Engine Position Sensor Circuit EPS
    122 Intake Manifold Pressure Sensor Circuit
    123 Intake Manifold Pressure Sensor Circuit
    131 Accelerator Position Sensor Choice
    131iss Accelerator Position Sensor Circuit
    131ivs Accelerator Position Sensor Circuit
    131sss Accelerator Position Sensor Circuit
    132 Accelerator Position Sensor Choice
    132iss Accelerator Position Sensor Circuit
    132ivs Accelerator Position Sensor Circuit
    132sss Accelerator Position Sensor Circuit
    135 Oil Pressure Sensor Circuit
    141 Oil Pressure Sensor Circuit
    143 Oil Pressure - Engine Protection
    144 Coolant Temperature Sensor Circuit
    145 Coolant Temperature Sensor Circuit
    151 Coolant Temperature - Engine Protection
    153 Intake Manifold Temperature Sensor Circuit
    154 Intake Manifold Temperature Sensor Circuit
    155 Intake Manifold Temperature Sensor - Engine Protection
    212 Oil Temperature Sensor Circuit
    213 Oil Temperature Sensor Circuit
    214 Oil Temperature - Engine Protection
    221 Ambient Air Pressure Sensor Circuit
    222 Ambient Air Pressure Sensor Circuit
    234 Engine Overspeed
    235 Engine Coolant Level - Engine Protection
    241 Vehicle Speed Sensor Circuit
    241auto Vehicle Speed Sensor Circuit
    241ind Vehicle Speed Sensor Circuit
    242 Vehicle Speed Sensor VSS Circuit
    243 Engine Brake Supply Circuit
    245 Engine Fan Clutch Supply Circuit
    249 Ambient Air Temperature Sensor Circuit
    254 Fuel Shutoff Solenoid Supply Circuit
    255 Fuel Shutoff, Fan Clutch, Engine Brake Supply Circuit
    256 Ambient Air Temperature Sensor Circuit
    267 Ambient Air Temperature Signal Incorrect
    269 Vehicle Anti-Theft Protection Activated
    289 Vehicle Accessory Shutdown Driver - Not Identifiable
    311 Injector Choice
    311n14 Injector Circuit
    311m11 Injector Circuit
    312 Injector Choice
    312n14 Injector Circuit
    312m11 Injector Circuit
    313 Injector Choice
    313n14 Injector Circuit
    313m11 Injector Circuit
    314 Injector Choice
    314n14 Injector Circuit
    314m11 Injector Circuit
    315 Injector Choice
    315n14 Injector Circuit
    315m11 Injector Circuit
    321 Injector Choice
    321n14 Injector Circuit
    321m11 Injector Circuit
    322 Injector Choice
    322n14 Injector Circuit
    322m11 Injector Circuit
    323 Injector Choice
    323n14 Injector Circuit
    323m11 Injector Circuit
    324 Injector Choice
    324n14 Injector Circuit
    324m11 Injector Circuit
    325 Injector Choice
    325n14 Injector Circuit
    325m11 Injector Circuit
    331 Injector Choice
    331n14 Injector Circuit
    331m11 Injector Circuit
    332 Injector Choice
    332n14 Injector Circuit
    332m11 Injector Circuit
    343 Fault Processing Computer FPC Chip
    352 Sensor Supply Circuit
    415 Oil Pressure - Engine Protection
    422 Coolant Level Sensor Circuit
    431 Idle Validation Switch Choice
    431iss Idle Validation Switch Circuit
    431ivs Idle Validation Switch Circuit
    431sss Idle Validation Switch Circuit
    432 Accelerator Pedal Circuit Choice
    432iss Accelerator Pedal Circuit
    432ivs Accelerator Pedal Circuit
    432sss Accelerator Pedal Circuit
    433 Intake Manifold Pressure Sensor Circuit
    434 Unswitched Battery Supply Circuit
    441 Unswitched Battery Supply Circuit
    442 Unswitched Battery Supply Circuit
    474 Starter Solenoid Lockout Relay Driver Circuit
    536 Autoshift Low Gear Actuator Lockout Solenoid
    537 Autoshift High Gear Actuator Shift Solenoid
    544 Top2 Transmission Circuit - Mechanical System Failure
    551 Idle Validation Switch Choice
    551iss Idle Validation Switch Circuit
    551ivs Idle Validation Switch Circuit
    551sss Idle Validation Switch Circuit
  6. jbatmick
    2,200
    2,511
    Dec 1, 2009
    hastings, Fl
  7. Rubberens
    Rubberens Bobtail Member
    45
    Dec 6, 2017
    What is this code refering to a sensor or something ? 255 Fuel Shutoff, Fan Clutch, Engine Brake Supply Circuit , i have count 255 for coolant sensor says active , engine postion sensor active also count 255 and injector #4 low or open C inactive count 255, n14 engine any help?
  8. mrbamcclain
    mrbamcclain Light Load Member
    258
    116
    May 25, 2011
    Hammond, La
    255 is the amount of times its been logged in the ECM. That's the max input though so as you're running those codes are constantly logging.
    Usually EPS doesn't set any lights or codes when it goes bad, so I'd start with the wiring and sensor there. If you're saying that all of those circuits are active you need to start checking your wiring for a short to ground.
