Looks like the 2 steel plug in are loose I will go buy a new sensor hopefully that work I can't get the codes because the dash bored is not working properly need to buy a new dash to get codes
Need help with engine questions
Discussion in 'Questions From New Drivers' started by Youngtrucker91, Sep 6, 2015.
Page 2 of 4
Idk what sel means it's turns off but I can turn it back on real quick
SEL-stop engine light. (red warning light.)
CEL-check engine light. (yellow warning light.)
When you turn motor off does your warning light also go out and how long before you have motor running does it come back on?
Have you checked level of coolant? Could be oil pressure or oil level. Not sure what sensors the stop engine light is wired for. -
It's only the red stop engine light
Coolant is full and oil I think it migth be the sensor because the pug ins are loose hopefully it's nothing major
I can turn it on like 10 second after it shuts off
It does have a orange ligth that says info on it is that maybe the check engine light?
I have a N14 in my Freightliner. Not sure about the Dash lights in a Volvo.
They all should cycle on and off when you start your truck. I don't know how to check the codes on your truck. On mine I have a toggle switch I turn on and turn key to start but just enough to turn electrical system on, not actuate the starter. My red light blinks on and off, you count the number of times it flashes and that is your code.The sequence will give you three numbers than repeat. Here is a link for the fault codes. Good luck.
http://www.diesel-service-parts.com/celect-plus-codes.html -
Thanks like I said hopefully it's nothing major because this was one of my big investments and it will suck to have to put money into this truck and it's still not up and running
Your truck being an 02 you will have to put money into it. TLC money.
Did you have a mechanic look your truck over.
I had a Volvo with an N14 motor. The red engine light would ever so lightly flash on and off driving under a load. Took it several times to a shop to have it look at. Everything was always ok.
Until that one day it stayed on bright as could be. Before then the light would never come on bright, it would not stay on, usually only climbing hills under a load it would flicker lightly on and off. It never shut the motor down.
TO shorten the story it was low oil pressure/volume. Dash gauge wasn't accurate. My main bearings seized.
Lesson learned, I had a spare in the driveway and the first thing I did was have the oil pump changed. Cheap enough to have done and what a piece of mind it gave me.
Good Luck
Page 2 of 4
