Need help with engine questions
Discussion in 'Questions From New Drivers' started by Youngtrucker91, Sep 6, 2015.
  1. Youngtrucker91
    Youngtrucker91 Light Load Member
    152
    49
    Aug 11, 2015
    The guy rebuilt the engine in 2013 he has all the paper work I called the shop they said yes that they did do that job and I did a test drive very thing check out good mecanic say it was good now this came up sucks but thanks for all your help
  3. Youngtrucker91
    152
    49
    Aug 11, 2015
    I all so saw that it's missing a battery could that be a problem also?
  4. Letz4wheel
    Letz4wheel Bobtail Member
    31
    24
    Aug 10, 2015
    If I remember right on the cummins you can unplug that sensor and it will run. You wouldn't want to run it like that forever but for testing it might help narrow it down. If that doesn't work jump the two wires in the plug together. One or the other should work.
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    You are going to want to get your dash cluster working properly.
    I had a low oil pressure problem that I chased for a week. Come to find out, it was a loose wire in the dash. Had it repaired and no problems since.
    My truck is an '01 Volvo w/N14
  6. Youngtrucker91
    152
    49
    Aug 11, 2015
    so what does the yellow info ligth me on the volvos?
  7. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Push the button on top of the right stalk-wipers, then you can go through the info.
    Digital gauges, fuel consumption, trip miles and codes.
  8. Youngtrucker91
    152
    49
    Aug 11, 2015
    Ok I need to buy a new dashboard it's burned you know were I can get one? Cheap lol if there such a thing
  9. Bakerman
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Have to call junkyards hope they have one kind of rare that they do though
    Also look on eBay
  10. Youngtrucker91
    152
    49
    Aug 11, 2015
  11. Youngtrucker91
    152
    49
    Aug 11, 2015
    I'm regrading getting this Volvo truck parts are so expensive the dash bored cluster is running me about 1800 brand new I should of done my research before I got this truck
    silver dollar Thanks this.
