Need help with gear ratio
Discussion in 'Canadian Truckers Forum' started by Ravind3r, Jul 15, 2023.
  1. Condi
    Condi Light Load Member
    124
    130
    Sep 9, 2012
    You’ll be fine. Just go buy another 600k mile truck when this one dies.
  3. mudflap77
    mudflap77 Heavy Load Member
    864
    1,314
    Oct 11, 2010
    South western Ontario
    That transmission is only rated to 110,000lbs/50,000kg and no oil cooler
    Albertaflatbed and Oxbow Thank this.
  4. Mchestnut1
    Mchestnut1 Bobtail Member
    28
    23
    Apr 13, 2020
    USA Florida
    I am in the same position. Wondering if my truck will pull tankers. 07 386 cat C-15 475hp 10speed 336 rear ratio.
    Going to be in florida only. All Flat. Truck empty weighs 18k and full 8k jetA or diesel that has to be like 56k then the trailer.
    When I pulled my Reefer trailer. I pulled some 79800 weight.
    You think the pete 386 c-15 475hp 10speed 336 rears will work for this?
    plus anyone have any suggestions for a better truck to move these heavy loads?
    I have found some deleted trucks at a bargain and some non-deleted newer 2018-2019 at a really great price too.
    I do believe I would like to stay away from the Dpf DEF nonsense and have the 1995-2007 models.
    Any suggestions will be welcomed
  5. liner
    liner Medium Load Member
    476
    684
    Mar 15, 2008
    ontario
    If you are just running in Florida you can only gross 80,000 lbs anyway unless you are running with some special permit so you will be OK.
  6. Mchestnut1
    28
    23
    Apr 13, 2020
    USA Florida
    Perfect
    Thanks
    I was wondering if this truck will move this kind of load
    Since truck prices are relatively low in pricing now.
    Any recommendations for buying a truck with better fuel economy that can Pull tanker loaded full diesel or jetA, AvGas
