Need help with getting a top bunk
Discussion in 'Freightliner Forum' started by Teg007, Aug 13, 2020.
  1. Teg007
    Teg007 Bobtail Member
    4
    Jun 29, 2017
    Hello,
    I have a 2013 freightliner cascadia with only 1 bed. I want to install a top bunk. It didn’t come with one. How would I go about it?
    thanks
  3. tommymonza
    tommymonza Road Train Member
    4,519
    12,849
    Sep 10, 2013
    S.W. Florida
  4. truckdriver31
    6,998
    8,363
    Sep 18, 2013
    just build a frame out of 1x1 and 3/4
  5. Gdog66223
    Gdog66223 Road Train Member
    1,871
    2,569
    Dec 30, 2017
    Coal Town
    Rideandrepair Thanks this.
  6. Teg007
    4
    Jun 29, 2017
    Why what?
  7. Teg007
    4
    Jun 29, 2017
    I thought of that but was unsure if that hold the weight of a person
    truckdriver31 Thanks this.
  8. Rideandrepair
    17,575
    56,937
    Aug 8, 2015
    I put one out of a Century in my old Classic. Pretty straight forward. Bolt the corners onto the triangle shaped corners, already in place on your Truck, then bolt the two little side brackets that hold it when folded down. You can get fancy, and add the latches that hold it in the up position I didn’t bother, just left it down all the time. It’s probably best to take one out yourself, to get a good idea how to install it. Might be cheaper too. You could build a frame. A long full size , Queen, or king size frame might work. Have to measure it. You can get them from Salvation Army store for $10. Use 1 to re enforce the bottom, in place of wood slats. Put a pice of 1/2” plywood down. Use some angle for brackets.
    Teg007 Thanks this.
