I just bought a bearcat980 for my 2018 international LT and it comes with everything already there the power wires and antenna even has a plug for a pa system anyway I know green wire is the hot wire so I hooked it up green=red and white=black but I'm not getting power I tried turning the key to on position still nothing I even started the truck and still nothing what am I missing
Need help with installation
Discussion in 'CB Radio Forum' started by Apollyon, Nov 7, 2017.
check your fuses in the fuse boxjessejamesdallas Thanks this.
I did but I'm not sure what ones. I know it should be accessories. All the fuses that are there look fine.
Fuse on radio power wire?
Pick up a cheap volt / ohm meter at Walmart, and see if you have 12 volts getting to the green and white wires. If there’s no power there, then you need to determine which fuse in the power box supplies power to these wires and see if it’s blown. The meter will take the guess work out of it.
jessejamesdallas Thanks this. -
No I took it to a shop and they hooked it to a power supply in their shop and it worked.
