Need opinions on 08 W900
Discussion in 'Ask An Owner Operator' started by BIGMIKE1, Jun 4, 2011.
  1. BIGMIKE1
    BIGMIKE1 Light Load Member
    257
    86
    Jan 23, 2010
    Looking at buying 08 KW W900 with 575 isx, 18 speed autoshift,3.55 rears. Does anyone know what kind of fuel mileage to expect, and how is the autoshift transmission as far as driveability and reliability? I have a T600 now and really want a hood, just trying to figure out how much fuel mileage ill have to give up for it[​IMG].
  3. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,165
    Jan 17, 2008
    Wherever and Whenever...
    What type of trailer do you plan on tugging?..
    What lanes?
    Will you always be hauling heavy (greater than 30K in/on the wagon)?
  4. BIGMIKE1
    257
    86
    Jan 23, 2010
    I pull a hopper O.T.R. so im always close to 80000 gross weight. MO,IA,IL.WI,MN,NE,KS,OK,AR,TX,SD.
  5. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    Ok.....
    Some flat....Some rolling hills.....A little mountain....
    But you're like me....I'm usually closer to 80K.....
    You should get at least 6.5-7........If you run under 68 mph....
    BIGMIKE1 Thanks this.
  6. BIGMIKE1
    257
    86
    Jan 23, 2010
    Well that would be great but im a little skeptical of those numbers, im only gettin 6.2 with my aero truck with isx, 13 spd, 3.55 rears now. But then again i only have a 400 hp isx.
  7. seabring
    seabring Road Train Member
    1,844
    1,883
    Apr 24, 2011
    i drive a 2005 w900 cat c15 acert 475 hp 18 speed 3.55 rears pulling reefers at max gross. I run otr all states. I get consistently 6.75mpg . i cruise at 1300 rpm (55-58mph). I would think maybe cummins isx would get a bit better mpg from what i hear. i know nothing of autoshift, so cant help much with that.
  8. BIGMIKE1
    257
    86
    Jan 23, 2010
    I run around 63 to 65 mph. I dont think i could run as slow as you do.
  9. Working Class Patriot
    12,683
    23,165
    Jan 17, 2008
    Just because you have 575 ponies doesn't mean you use them full time....
    My 379 had Series 60 430 bumped to 470.....It would climb the grade to the Eisenhower tunnel with a 48k load in 6th (13 speed) running 20-25 if I was lucky... The best MPG that rig ever got was 5.5....
    My 386 has a 550 ISX, 18 speed, 3.23....I can climb the same grade in 12th...sometimes 13th running at 80k gross....I have gotten as much as 8 mpg running the flats of I-40....But if I use all the ponies and run over 75.....MPG can drop lower than 3 mpg.....:biggrin_25524:
    The thing is...every load is different....Every lane is different.....
    Every day is different......Trying to get 8 mpg for example, every time you run...Is impossible....I don't care what Kevin Rutherford says....It won't happen every time you run.....
  10. seabring
    1,844
    1,883
    Apr 24, 2011
    its governed at 62 mph so i just have to hurry up and wait ! it really doesnt bother me going that speed , im still on time and still get were i want to get to each day. it would be nice to be able to get going a bit faster somedays but its really not that bad.
  11. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    i suggest you learn to drive like an owner operator and not like a company driver.
    i would be looking for a 3.30'ish rear gear
    Working Class Patriot Thanks this.
