Need Serious Engine Help!
Discussion in 'Volvo Forum' started by pavel94, Mar 15, 2013.
  1. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    JB Weld that hole, put in fresh oil and roll on :biggrin_25525:
    cetanediesel Thanks this.
  3. dannythetrucker
    dannythetrucker Road Train Member
    2,856
    4,032
    May 26, 2011
    everywhere, man
    somebody wasn't checking the oil every day ! tsk, tsk, tssk.
  4. fortycalglock
    fortycalglock Road Train Member
    6,164
    6,613
    Jun 25, 2011
    Tourist Town, FL
    That's what the last owner did. The same thing happened to a guy I used to know with the ISX. If you dosimeter research, there are many ventilated ISX blocks.
  5. nasriza
    nasriza Road Train Member
    2,407
    2,077
    Feb 1, 2013
    Chicago, IL
    Isx engines are notorious for breaking the block and u just are extremely unlucky u can probably get a used engine from hribar in Racine for a lot cheaper than 12 k probably close to half that it probably broke the block right where the oil pan bolts on if the engine is not turning over it completely done beyond repair. Get a used engine and throw it in there or Ask for the price on a short block from cummins which is pretty much block crank rods bearings you're gear train should be good u might need a head but make sure wherever u have it done they don't screw u over for a bunch of parts u don't need and dealer is not always the answer they just overcharge for something u can get done at a good capable shop.
  6. Epsilon
    Epsilon Bobtail Member
    Well, I was looking for a while for such a shop, couldn't find one. Any ideas? I have pretty much the same problem! Thanks.
  7. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    Why would you pay 12,000$ (maybe 15-16,000$ instaled )for a used motor, after a couple of months may need another one. I would buy the reman ; this motors are sold with warranty 250,000 miles/2 years and many auxiliary new parts; turbo, EGRs, pumps,.. ; Was the reman priced 24,000$ installed? I would consider a Volvo D12 reman , from what I know are better on fuel and more reliable. I was at Volvo in Waco,TX last week , the D12 reman was priced 19,999$ +installation.
  8. TheEnglishMan
    TheEnglishMan Light Load Member
    231
    60
    Oct 3, 2012
    I think you are just unlucky. Every truck old and new is risk. Best thing is to get it fixed and get it making money ASAP. I personally would go for the reman engine. Get a Cummins shop or a Volvo dealer to do the install so you get the warranty. The Volvo warranty on the d12 remans are excellent but to convert from a cummins engine to a volvo power plant my not be cost effective. You would need a whole bunch of extra stuff in addition to the engine.
  9. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    You can buy an 06 volvo for $18000 and have a extra truck for parts. $20000 for a engine in an old truck is INSANE. Build it your self, or if you cant then buy a new one with a warranty. You need to be a full service garage to make money with a used truck.
