Need some good advice....
Discussion in 'Heavy Haul Trucking Forum' started by Dirtbike Dan, Aug 24, 2020.
  1. Dirtbike Dan
    Dirtbike Dan Bobtail Member
    I'm trying to figure out the best trailer to haul my 160 excavator and 8 ton dozer together. Excavator weighs 38000lbs and the shipping length end to end is 28 feet. The dozer is 13.3 feet long and weighs 17,000lbs. End to end both machines are 40feet long. I have a w900B with a wet kit but I'm leaning towards a scissorneck low boy. I also think a step deck with some good ramps would work well also but around here these trailers are about the same price. Any advice is appreciated Thank you -Dan
  3. JDHIGGINS44
    JDHIGGINS44 Light Load Member
    113
    272
    Jun 29, 2015
    Waynesburg, PA
    Not sure where you are located and what permitting options would be or possible blanket exceptions, but in my neck of the woods that move would never be possible legally anyways. On the other hand if legality isn't an issue as far as deck space I would look at either a landoll "expensive" or a 53' step deck with ramps.
    hwrdbd Thanks this.
  4. hwrdbd
    hwrdbd Bobtail Member
    12
    52
    Apr 11, 2013
    Depending on how good you are at tetris you can quite certainly find a boom/blade position and orientation that minimizes your overall length. Regardless of that, as previously stated, you will be over 80k gross no matter what kind of trailer you can find. I don't know the state laws for permitting wherever you're located, but I'm not sure that you'll be allowed to permit for the weight with a divisible load such as that.
  5. Rusty nails
    Rusty nails Bobtail Member
    7
    7
    Aug 26, 2020
    I don’t see how you are going to be able to haul them both. Together that’s 57,000. You can’t permit weight for multiple pieces in most places. And you’ll never find a truck and trailer that’s 23,000 that is capable of what you want. I say look for a landoll trailer.
    TripleSix Thanks this.
  6. shawnhhllc
    shawnhhllc Medium Load Member
    306
    2,341
    Feb 9, 2020
    florida
    Stepdeck and ramps gets old really quick. We have a handful of places that we deliver too. Idk maybe I’m just the lucky guy that always has to get his ramps out. Landoll is probably your best bet.
  7. JDHIGGINS44
    113
    272
    Jun 29, 2015
    Waynesburg, PA
    I did not mean a step deck with ramps that you need to manhandle each time. We run a large fleet of 53' Dorseys with a built in beaver tail and ramps. They are spring assist you can lift with one hand.
    kylefitzy Thanks this.
  8. Rusty nails
    7
    7
    Aug 26, 2020
    A step deck will be fine for the 170. If you go with a larger machine later on I wouldn’t suggest a step deck. The outer rail and cross members are not that big. And steps are bad about cracking at the drop if they are loaded heavy all the time.
    You can get them built however you want, so my statement is a generalization. 90% of what you will find is just a run of the mill step deck.
  9. Rusty nails
    7
    7
    Aug 26, 2020
    Yes a landoll is more expensive and heavier, but are way more versatile if you are moving smaller pieces of equipment.
