I'm not new to driving, but new to CB radios
I can figure out how to install, but I'm not too sure what to do about the antenna
I'm not sure where the last driver has this wire routed
Also, what is that in the middle?
Need some help CB Antenna routing?
Discussion in 'CB Radio Forum' started by MilkOnMyWhiskers, Jan 26, 2019.
The yellow appears to be labeled with a white tag. red and black are normally powered but check with a circuit tester before hooking up your radio. Check your swr before hooking up the radio as factory coax may be bad or disconnected.
I bought a new coax just in case
I'm not entirely sure what the yellow is -
The “usual” arrangement is:
Coax
Twin-lead power
External speaker jack.
But there ain’t quite no telling what you have there past coax. If the twin lead was cut, buy the factory replacement at dealer counter.
Red lead could be anything. Camera. Speed detector. Purple good buddy windshield shield lamps, etc.
