Need some help with a 2012 Pro Star
Discussion in 'International Forum' started by flightwatch, Oct 5, 2013.
  1. flightwatch
    flightwatch Road Train Member
    1,249
    1,251
    Jun 22, 2011
    Somewhere in Texas
    I won't get into what I really think about this truck, but it's mine for the next month...so I need some help trying figure it out. When I got into the truck early last week, everything was working fine. I tried hooking my cb up, but couldn't get any power from it. I checked the fuse, but it was fine. Ever since then, however, A few things seem wacky. The radio shuts itself off after about an hour, and the steering wheel mounted radio controls don't work. I don't have the radio remote in the sleeper, so I don't know why the radio is all of the sudden doing this. Is there some type of hidden switch I might have pressed?
  3. bowlwinkle
    bowlwinkle Heavy Load Member
    828
    713
    Aug 27, 2008
    Ankeny, IA
    not that I know of
  4. lars
    lars Bobtail Member
    41
    18
    Mar 20, 2010
    greenville s.c.
    Check the breakers. Passenger side behind dash cover. Mine was doing the same thing
  5. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    does it have a MAXXFORT engine? That may be the Issue!
  6. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    Aren't they really MAXXFIX?
    But it does sound like a breaker is tripping for this to happen.
  7. Heavyd
    Heavyd Road Train Member
    7,829
    6,279
    Feb 4, 2009
    Is the radio shutting off while you are driving? The premium radio does have a time-out feature where it will shut off after 1 hour after the ignition power has been turned off.
  8. flightwatch
    1,249
    1,251
    Jun 22, 2011
    Somewhere in Texas
    Yes I am driving. That's why I thought I might have inadvertently entered some super secret prostar code. I checked the breakers, and they're fine.
  9. Heavyd
    7,829
    6,279
    Feb 4, 2009
    If you turn the key on and the radio turns on, it is getting ignition power. If it is turning off later while driving the radio is loosing either ignition or battery power somewhere. The CB wiring runs up the pillar, no where near the AM/FM radio. BUT, they do share the same breaker/fuse. My diagram shows there should be a 10 amp breaker or fuse in spot F4-F. Make sure your CB radio isn't drawing too much power or that the terminals aren't bent or spread where the breaker plugs in. Wiggle the wiring directly under the fuse block and around the area and see if any of the radios cut out. The wiring directly in behind the AM/FM radio tends to get pinched or crushed between the back of the radio and the rear support for the radio.
  10. CertifiedSweetie
    CertifiedSweetie Road Train Member
    1,489
    1,634
    Nov 18, 2008
    Pittsburgh,Pa
    I had a 2012 prostar star and amung the many issues I had 1 was that the radio shut off every 30 minutes. It took international 3 frickin days to figure it out. Its something to do with the timer and/or wiring.
  11. MaxxGuy729
    MaxxGuy729 Bobtail Member
    Oct 6, 2013
    It was proli the load shed unit that was replaced. Its located under the dash on the engine cover. I have ran into the same issue at the dealer I work at.
    baha Thanks this.
