Need some help with an International 8600
Discussion in 'International Forum' started by Onefast96svt, Jan 15, 2013.
  1. Onefast96svt
    Onefast96svt Bobtail Member
    I have a few random problems with a company truck that seems like the mechanics can't or don't care about fixing. I was wondering if a few of you could chime in if you know what may be going on so I can fix it myself.
    1 I think the blend door is or has gone bad. Air only comes out of vents and not defrost of floor. What's the easiest way to check or replace or just slap it a few times?
    2 it spits and spudders slot with random on and off engine light. I believe they said they cleaned the EGR(or similar diesel part) once then may cleaned again or replaced second time but its back to doing it again.
    3 are the lights for the gauges in the dash bulbs or LEDs? I have some out and was told its time consuming to replace.
    4 the headlights I've tried to aim myself on the side of the road after they just torqued them to the sky. But I still can't see anything. The haze has been cleaned off so there clear, I put new xtra vision 9007 in, but still not much difference from low to high beams.
    5 what's the secret to get the drivers door to stop whistling in my ear? I put some foam strips along doors edge which worked great but water started leaking in so I had to remove it.
    Thanks for any help, really appreciate the help!
  3. Heavyd
    Heavyd Road Train Member
    7,830
    6,282
    Feb 4, 2009
    1 - Probably an actuator motor. Located up in the dash around the upper right corner of the rear engine cover, not easy to get to. (problem could be the dial too though.)
    2 - Need to know engine, model and year. Could be anything.
    3 - bulbs, about $10 each. Cluster has to come out and be disassembled to replaced. Not hard.
    4 - Headlight adjusters are likely stripped out.
    5 - Doors have a design flaw, they are too flimsy. What you can do is pull down the weather stripping along the top and front of the door opening. That thin strip of sheet metal that the weather stripping goes on can be pounded or bent outward so when the weather stripping is back on it makes a tighter seal with the door. I wouldn't try loosening the door hinges, or striker unless you know what you are doing. This can lead to more problems.
