Need some insight with height.
Discussion in 'Experienced Truckers' Advice' started by Davidsti1, Aug 22, 2020.
  1. Davidsti1
    Davidsti1 Bobtail Member
    39
    14
    May 30, 2015
    Hello pro drivers.
    2 weeks ago I got a Volvo 780 and I noticed They raised the 5th wheel with metal bars. I Connected my trailer and measured exactly 13’6, I asked another driver that was parked Next to me to measure his trailer (Same Moving trailer specs) and he’s right at 13’4.
    Now my question is if I could clear 13’6 Bridges or I should remove the raisers. It’s Welded in few points so a little headache to do It.
    Thanks.
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Remove them. They where added for running a tanker trailer. No point in rising your trailer to where it will most likely hit things, especially since you’re towing a moving van so you’re more likely to find low branches and telephone lines in residential areas.
  4. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    You're fine at 13 6
    One of our vans with 11R24.5 on the tractor measures 13,7-13,7.5 and i run a lot of jersey/Rochester/Albany w/o issues. Just use your head and you'll be fine.
    If you own the truck take em off
    Davidsti1 Thanks this.
  5. Claytonbigsby
    Claytonbigsby Bobtail Member
    46
    112
    Mar 31, 2019
    If you take them out you will lose some clearance between your rear fenders and bottom of trailer. That rear panel looks like it will become an easy target for a kingpin too
    wis bang, Davidsti1 and p608 Thank this.
  6. snowwy
    snowwy Road Train Member
    20,612
    13,333
    Jul 6, 2009
    Remove the fenders and bars.
    Standard height is 13.2 anyways. I wouldn't want to mess with 13.6 on the east coast.
    Put yourself up along side the megas and compare trailer heights.
  7. Cat sdp
    Cat sdp . .
    21,319
    76,339
    Apr 8, 2012
    Orion's Belt
    Do you break out in a cold sweat on the cross Bronx ...?
    Brettj3876 Thanks this.
  8. Brettj3876
    11,257
    54,060
    Nov 18, 2014
    Land of local
    I cross the hudson Newburgh and above LOL. There was a few places in the Ironbound section of newark i dropped the suspension just to be safe and creeped under
    Cat sdp Thanks this.
  9. 062
    062 Road Train Member
    6,344
    34,002
    Oct 20, 2013
    Tree limbs will be your biggest problem. I’m 13’7.5 and set off the warning signs around Memphis. I have experimented and found that it takes 5 seconds to drop 2”. So far I haven’t hit the 13’8 bridges on the south side.
    Also scales have height sensors,so you have to watch for those.
  10. Brandonpdx
    Brandonpdx Road Train Member
    4,716
    4,846
    Dec 27, 2007
    Elkhart, IN
    Murray St.
    That’s the one everybody gets under trying to get into Ironbound off of 21/McCarter Hwy. it’s a tight one though.
  11. Brandonpdx
    4,716
    4,846
    Dec 27, 2007
    Elkhart, IN
    13’6 is fine. I stay in the middle lane through there anyway.
