Need tips on backing a 40ft Trailer!
Discussion in 'Questions From New Drivers' started by Thull, Apr 11, 2017.
  1. Thull
    Thull Medium Load Member
    652
    921
    Dec 7, 2015
    Baton Rouge, Louisiana
    i didn't do much backing in my 10 months with Schneider Bulk cause I rarely had to back or especially never alley dock. Now I pull 40 ft Containers with Dupre Logistics & the yard is kind of tight. I've only been here 2 weeks & 'pay times can just pull through but over the weekend we were busy so Trailer everywhere so all you can do is back in to spots available. I'm catching hell trying to back this 40 ft trailer between 2 other trailers. Any tips on alley docking or 90 degree on a 40 ft trailer. I've watched some videos on how they back up a 53ft van but the key places to keep your eye on or where to start turning the wheel don't really apply in the sense since I have a shorter trailer & it reacts quicker. Thanks!
  3. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Hard to teach it. Especially the finer points. Practice, experience, and learning from your mistakes works every time it's tried.
    I don't think shorter trailers is the problem so much as backing in general. Shorter trailers only mean things happen quicker and you should make less drastic maneuvers and start things (setup turns) a little sooner
  4. Ezrider_48501
    3,845
    5,135
    Apr 2, 2011
    bismarck, nd
    drive the trailer not the truck, watch where your trailer tires are going, make small adjustments and drive the trailer in and follow it with the truck.
  5. Thull
    652
    921
    Dec 7, 2015
    That's what I hear it's not really something someone can tell you. You just have to keep practicing it.
    austinmike and KillingTime Thank this.
  6. jinxutoo
    jinxutoo Light Load Member
    134
    224
    Jan 17, 2012
    Illinois
    My opinion is that backing is 90% your set up. Get the trailer aimed at the hole with your set up and drive it in.
    If in doubt get out and look. G.O.A.L.
    Thull, G13Tomcat and KillingTime Thank this.
  7. Just passing by
    Just passing by Road Train Member
    1,176
    3,140
    Feb 25, 2017
    Backing up was never my forte... but I learn that if I am pulling up to correct myself for the third time it's best to go around and restart from scratch.
  8. jethro712
    jethro712 Medium Load Member
    604
    6,035
    Aug 31, 2014
    jmo, shorter trl, shorter setup. do a lil less setup each time til u get the correct angle/distance. use your minds eye & all you mirrors. complete stop before jacking the wheels the other way. idle, no throttle. G.O.A.L. every ten feet. its a P.i.a. but good exercise. good luck
  9. PacoTaco
    PacoTaco Medium Load Member
    519
    2,556
    Apr 16, 2016
    Everywhere man
    I haul a 28 footer sometimes. It's quite different than a 53. Make little adjustments or it will get away from you in a hurry.
    SingingWolf and sevenmph Thank this.
  10. sevenmph
    sevenmph Road Train Member
    2,961
    14,946
    Jan 26, 2007
    Pinellas county Florida
    I've had 32, 40, 45, 48, 53. The shorter it is the faster it reacts. I'll repeat what others have said. Small turns and adjustments. If you go one inch over parallel, you're not getting it back. Pull up.
    sdaniel Thanks this.
  11. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,996
    19,137
    Mar 9, 2014
    In a van down by the River.
    Set up the same as a 53' you drove in school. Keep in mind the shorter the trailer the faster it off tracks and you have to correct.
