Need tips to make CB easier to hear/understand
Discussion in 'CB Radio Forum' started by BaddTrucker, May 29, 2020.
  1. BaddTrucker
    BaddTrucker Bobtail Member
    I have some hearing loss making it difficult to hear sometimes with a noisy background and find it difficult at times to understand what is said on the cb.
    I bought a Wilson 5” external speaker and that helps some. Other than controlling noise in the truck, do you guys have any tips? I am just using a Uniden pro505xl.
    Thanks
  3. Ridgeline
    22,752
    124,029
    Naptown Muduck and rabbiporkchop Thank this.
  4. jammer910Z
    jammer910Z Road Train Member
    2,446
    6,525
    May 28, 2015
    Turn off other distractions such as the XM or book on tape.
    Turn up the volume.
    Mount the external speaker up above the drivers door, pointing down towards you.. focusing sound waves directly at you instead of dispersing into the cab.
    rabbiporkchop and Muddydog79 Thank this.
  5. Naptown Muduck
    Naptown Muduck Light Load Member
    96
    78
    Jul 30, 2018
    I have the noise cancelling speaker too. It helps a lot. I got mine from DXEngineering.
    Timin770 Thanks this.
  6. 169
    169 Bobtail Member
    12
    Jun 2, 2020
    Headphones
  7. Night Stalker10
    Night Stalker10 Road Train Member
    1,699
    1,271
    Jun 26, 2017
    I wouldn't use headphones. If someone with a so called loud and proud radio starts talking, they may damage your hearing. It's bad enough with the external speaker mounted behind my head. Many times I've had to quickly reach up and turn the volume down when someone would start blasting in, but I wasn't quick enough, and it makes my ears hurt a little.
  8. Dave124
    Dave124 Light Load Member
    87
    72
    Mar 11, 2019
    Younger guys, start wearing ear plugs in the cab while driving because this is where you will end up. The cab noise level is not safe long term. Engine under load with engine cooling fan screaming is 100db in my truck. Add in radios turned up so you can hear them above that noise and the hearing damage is inevitable.
    LoSt_AgAiN and Night Stalker10 Thank this.
  9. 169
    169 Bobtail Member
    12
    Jun 2, 2020
    169 Bobtail Member
    12
    Jun 2, 2020
    Peterbilt? Fans in the Freightliner and Internationals was never an issue. I do have ringing in one ear and that was from talking skip all day and night and the white noise was high in frequency.
