Need your advise with a scale ticket
Discussion in 'Experienced Truckers' Advice' started by jjpaez123, Sep 27, 2020.
  1. jjpaez123
    jjpaez123 Bobtail Member
    24
    11
    Dec 26, 2014
    this driver has not fuel aparently and he is saying he is overweight.
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    How much fuel does he have. How far is the trip?
  4. Kyle G.
    Kyle G. Road Train Member
    3,901
    20,575
    Jan 23, 2016
    Eastern Iowa
    Yes, his drive axles and trailer axles are overweight.
    I suppose its possible that he could transfer that weight by sliding 5th wheel forward and tandems back... but it's hard to say without knowing where they are set now.
    Then again, it's not over by much... I guess start by sliding 5th wheel forward and see where that gets you
    tscottme, stillwurkin and gentleroger Thank this.
  5. jjpaez123
    24
    11
    Dec 26, 2014
    Toughkenamon, PA I dont know how much fuel he has. : ( I though he was supposed to fuel before scaling.
  6. Rideandrepair
    17,559
    56,882
    Aug 8, 2015
    He’s only got room for 10 gallons, even if he gets axles legal, that won’t get him far. If he can’t get the load reworked. I would slide the trailer forward, 2 holes, if possible. Put 50 gallons of fuel in, and run with it. He’ll have about 300 lbs over on Drives, May be overlooked at the scales. He’ll have to get 40-50 gallons every 250-300 miles. It all depends on where the scales are and if they’re open. Pa. Is probably not open today. Where’s he going? California? Better get the load fixed. Ohio? Run with it. Going to take a little planning.
  7. jjpaez123
    24
    11
    Dec 26, 2014
    Thank you! Destination is Toughkenamon, PA
    Rideandrepair Thanks this.
  8. Hammer166
    7,605
    27,792
    Aug 18, 2007
    ~8600+' and loving it!
    WTH? Leave the trailer alone! Slide a couple holes forward on the 5th wheel, and that will leave him pretty well balanced.
    d281833, I glide 47, LoboSolo and 5 others Thank this.
  9. Rideandrepair
    17,559
    56,882
    Aug 8, 2015
    Why would you not max out the trailer, if possible. That should be the first thing done, then try to slide 5th and transfer weight from drives to steers, if possible. The goal being to lighten up drives, for fuel. Hello?
  10. rachi
    rachi Road Train Member
    4,246
    5,231
    Feb 25, 2010
    SoCal
    If you had an APU then your allowed 400 over on the drives in most states.
  11. nikmirbre
    nikmirbre Road Train Member
    5,585
    10,338
    Jul 27, 2011
    High Point NC
    Is this a tandem van or a spread axle flat??
