New Addition To My Workbench
Discussion in 'CB Radio Forum' started by delta5, Aug 21, 2016.
  1. delta5
    delta5 Road Train Member
    1,193
    7,404
    Sep 9, 2010
    Just snagged a nice Sencore CB42 test center today. Here is what I have for test gear so far:
    Sencore CB42
    Heathkit IM4100 freq counter
    Elenco SG 9500 RF Signal Generator
    A good VOM
    Workman watt and mod meter
    Kenwood SM220 monitor scope
    Next on the list is a decent VTVM.
    Not bad for a noob?
  3. Ridgeline
    22,730
    123,515
    The sencore is a nice unit.
    Good addition to the bench.
    I had a few of them and sold one of them to some CB guy in Ohio who moved out west and setup shop some where out there.
    Why the VTVM?
    I hardly use any of mine.
    Get a really good high impedance VM (20k or higher) and use that. I just bought a German made one (DDR) off of eBay that came recommended from a guy who restores high end audio stuff. He grew up in the DDR and said that they were made like tanks and hardly ever go bad unless abused.
  4. delta5
    1,193
    7,404
    Sep 9, 2010
    I thought a vtvm could only be used across the speaker terminals when aligning the receiver section.
  5. Ridgeline
    22,730
    123,515
    TO start with I made a typo, it should be 10 to 11 Mohm impedance, not 20k. I was thinking about something else when I posted that. My daughter "corrected" me.
    Anywho ... You would think the VTVM is needed because the service lit says so but at the time there was nothing else nor anyone thought of updating the lit. What a VTVM provides is the high impedance input needed to measure the voltage across the output without effecting the readings. A good VM (FET type will work) with high impedance does the same thing as does a digital multi meter like any fluke 8000 series DMM. I just looked on ebay, there are a bunch for under $100.
  6. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    You mean this guy from Hubbard Ohio?
  7. delta5
    1,193
    7,404
    Sep 9, 2010
    Well, crap. My new Sencore CB42 arrived today, but I had to leave for Florida before it got here. Anyone know of a place that can check it out and calibrate it? I'm sure it will probably need new electrolytic caps etc due to its age.
  8. Ridgeline
    22,730
    123,515
    Why would it need caps?
    If it has been used often enough, they should be fine. It is only when things sit for long periods of time is when you worry.
    rabbiporkchop Thanks this.
  9. delta5
    1,193
    7,404
    Sep 9, 2010
    Would the display react slowly enough when you are peaking the IF stages? it seems to me that a mechanical movement would be better for that.
  10. Ridgeline
    22,730
    123,515
    I don't really understand the question, I've always used a scope and/or audio meter (heathkit) when tuning the if strip.
    The audio watt meter to me was useless on the sencore.
  11. delta5
    1,193
    7,404
    Sep 9, 2010
    Oh I see, you were using the scope to read voltage on the speaker terminals?
