New Cat Injectors
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by awright, May 18, 2018.
  1. awright
    awright Light Load Member
    86
    16
    Dec 20, 2016
    Anyone know how to purchase a new sent of injectors for a Cat c-15 625hp? Instead of these unreliable reman injectors. I am tired of going to the shop to fix my rough running and vibrating truck, to find out the injjectors that I just replaced a year ago are mis firing again. Getting old and costly CAT people.
  3. spsauerland
    spsauerland Road Train Member
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Ask for new, not reman. Should be able to get @ any dealer.
    Diesel Dave Thanks this.
  4. Luwi67
    Luwi67 Heavy Load Member
    750
    485
    Oct 24, 2012
    Long island
    All the threads I've read over the years about Cat injectors gave me the impression that even new injectors were all over the place as far as tolerances. Is this a fact?
  5. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Replace your injectors with a platinum kit then you get four years free replacement?
  6. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Platinum kit ones are reman. If you want new, ask for new. I have had way better luck with new vs reman. Much smoother and less prone to failure.
  7. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    How much more are the new I just 600 on a reman
  8. spsauerland
    4,296
    10,891
    May 31, 2010
    West Harrison, In
    Usually from $150 to $300 more. Parts guys will work with you on price. I never ever pay the price quoted.
  9. awright
    86
    16
    Dec 20, 2016
    Thank you for all the info. I will get to checking on some new ones. I was told that it was very rare to find NEW injectors.
  10. awright
    86
    16
    Dec 20, 2016
    Is there something else that is causing my injector failure, I only got about six months out of #1 and had to replace, and a year on #2 and now it needs replaced. Is there something else I should be looking into, or is this just typical reman junk that the manufactures shove down our throat and drain our pockets, and cost us much down time.
    spsauerland Thanks this.
  11. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    Check your cams maybe the install was bad on the injectors themselves
