New coax T800?
Discussion in 'CB Radio Forum' started by Tperkins1023, Apr 24, 2016.
  1. Tperkins1023
    Tperkins1023 Bobtail Member
    Has anyone ever replaced the coax on a Kenworth T800? Just got the truck and someone cut the factory coax. I tried snaking the coax through from the outside but couldn't get the connector around the corner. Has anyone ever taken apart the overhead compartment? Thanks for any and all help
  3. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    This is what I use to fish cable through a mirror arm. If I can fish a piece of coat hanger through the arm I can attach one side of the coat hanger to the cable sock which gets tighter the more you pull it and it pulls the cable right through the arm.
  4. Xcis
    Xcis Medium Load Member
    497
    269
    Jul 9, 2008
    Bridgeport, Pa
    .When you are speaking about getting the connector around the corner, are you referring to the connector on the cable that goes to the radio? If so, you will most likely have to remove the connector and reconnect the connector to the coax after it has been run through to the radio.
    ....Smaller diameter coax cable may make it slightly easier to maneuver but not by much.
  5. rabbiporkchop
    9,678
    6,545
    Feb 9, 2012
    Wapwallopen, Pa
    FME connectors usually slip right through the mirror arm.
