New guy, First truck. Need some engine advice! 3406E power.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by double brew, Mar 7, 2015.
  1. double brew
    double brew Light Load Member
    76
    20
    Mar 7, 2015
    No on automatic trans. It's a super 10 with auto 9-10. Kinda dumb, so I had it turned off. The only checking for leaks I've done is spraying starting fluid at all the couplings and joints.
  3. rank
    rank Road Train Member
    9,907
    113,497
    Feb 11, 2010
    Ahh. Do you know how to use that test kit you were talking about?
  4. wore out
    wore out Numbered Classic
    18,226
    230,884
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    The reason spraying starting fluid will not find a boost leak is that a Diesel engine does not have vacuum in the sense a gasoline engine does. I think you posted something about being into gasoline turbo engines. If you notice there boost gauges show vacuum then zero then boost pressure. So at idle a leak will still suck on a gas engine once the turbo starts spinning the suck turns to blow or pressure. A diesel lacks this initial suck. The best way to check for boost leaks is take the intake pipe off the front of turbo. Find a coffee can or oil filter what ever will fit in the rubber elbow, put it in the top and clamp it. Take the plug out of the elbow on the left side and put 10 pound or so of shop air to it thru a regulator. If you don't hear it immediately start looking with soap and water. You will loose a little thru the engine but not enough to get worried over. This checks everything as if the engine is running, not just air to air. Tgere is a 1/4 inch pipe plug directly under elbow on the bottom of the head that gets left out. There are freeze plugs on the bottom of the head that seal the intake to that do not come installed on a CAT reman head that could leak if they are not put in straight. Hopefully it's much easier than the freeze plugs I have only seen that one time.
    tsavory and Cetane+ Thank this.
  5. rank
    9,907
    113,497
    Feb 11, 2010
    Yep what he said.
    I've only ever checked from turbo to intake via the air to air. It never occurred to me that I could check the whole engine without leaking a bunch past the open valves. Sensing that I might be about to learn something here.
    EDIT: yeah the light bulb just went off. The key is to cap off the turbo.
    wore out and Cetane+ Thank this.
  6. double brew
    76
    20
    Mar 7, 2015
    Yea, I've used them before. I've never known about no vacuum on the diesels. Thanks! I'll check it out next time I'm home. I'll also hook onto the trauler and see how different it pulls.
  7. double brew
    76
    20
    Mar 7, 2015
    Also, the turbo on the truck is not the correct one said the cat guy. It is a borg warner turbo with an internal waste gate.
    Pn 147259
    model s410g
    Anyone tell me more about this turbo?
  8. FunkRider
    FunkRider Light Load Member
    87
    29
    Jul 22, 2009
    Hamilton, Ontario
  9. swaan
    swaan Road Train Member
    2,942
    4,376
    Jul 12, 2009
    BC canada
    You have the part # wrong. It's a 174259. Its a replacement borg Warner turbo for a 410-435 hp E-model.
  10. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    Wrong !
    That turbo you listed is a 175963. Yes it's for a 600 hp 15.8 L cat.
    He has the 174259. For a lower hp 14.6L cat.
  11. swaan
    2,942
    4,376
    Jul 12, 2009
    BC canada
    That is the correct borg Warner replacement turbo for your 435 hp engine. 174259 pn.
    Now that you put a 550 file in your ECM be very carefull you don't over speed that turbo. It's on the small side for a 550.
