New guy, need advice
Discussion in 'The Welcome Wagon' started by J.J., Feb 23, 2013.
  1. J.J.
    J.J. Bobtail Member
    5
    Bountiful, Utah
    I'm a new guy to the trucking industry. I've always wanted to be a trucker, however, I suffer from a hearing impairment. I've been hearing impaired since birth and I've recently found out that you have to pass the hearing requirements in order to be a trucker. So my question is what are the hearing requirements?
  3. critters
    critters <b>Late For Dinner</b>
    1,444
    2,440
    Jul 16, 2011
    traverse city,MI
    just a standard hearing test,do you wear hearing aids? i have seen drivers that do,talk to the recruiters and ask they should be able to help you out .Good Luck and welcome to the forum.
  4. J.J.
    J.J. Bobtail Member
    5
    Bountiful, Utah
    I do wear hearing aids. Thanks for the advice. I'll try it out.
  5. critters
    1,444
    2,440
    Jul 16, 2011
    traverse city,MI
    keep us posted on how you do Good Luck.
    J.J. Thanks this.
  6. WV_Daddys_Girl
    WV_Daddys_Girl <b>Crusty Ole' Wifey</b>
    553
    1,999
    Jan 26, 2013
    Virginia
    Welcome to TTR, J.J.!
    J.J. Thanks this.
  7. RickG
    RickG Road Train Member
    12,812
    6,137
    Jul 22, 2008
    Owensboro , KY
    A couple of years ago I thought I barely passed a hearing test for my DOT physical . Worried about passing my next physical I had my hearing tested and the doctor did say I needed hearing aids .
    Went I went for my recent physical the doctor said "You didn't have hearing aids the last time . Did you damage your hearing ? "
    I explained the situation . I didn't want to fail the test and be disqualified because you can't get hearing aids overnight . The doctor suggested I pass the test without the hearing aids . I did and I passed .
    To address your concerns if you have hearing aids there is simply a box on your medical card the physician checks that says "Requires Hearing Aid "
    J.J. Thanks this.
  8. Chinatown
    Chinatown Road Train Member
    77,867
    184,970
    Aug 28, 2011
    Henderson, NV & Orient
    If you can afford it, get a DOT physical on your own, then if you pass, apply for a trucking school.
    J.J. Thanks this.
  9. J.J.
    J.J. Bobtail Member
    5
    Bountiful, Utah
    It's that simple? I was worried I might have to go through this long and tedious testing procedure just to have them say no. I appreciate your story. Cleared a few things up.
  10. J.J.
    J.J. Bobtail Member
    5
    Bountiful, Utah
    I'll look into that. Might be easier.
  11. superpet39
    superpet39 Road Train Member
    1,161
    619
    Jan 27, 2013
    Bay Area California
    Welcome to TTR, keep us updated if you can
