New issues on 04 670 ISX
Discussion in 'Volvo Forum' started by Slow302, Nov 15, 2014.
  1. Slow302
    Slow302 Medium Load Member
    348
    117
    Jul 12, 2013
    MO
    Well i got new code on 04 Volvo 670 with 475 ISX 13 speed. It stays active for a few seconds and than goes inactive
    MID128 PID27 FMI13
    It says out of calibration
    I found it can be EGR, Turbo actuator or VGR
    Looks like its running rough when code is there but fine after code is inactive
    What could be this time
    Thanks
  3. bjytech
    bjytech Light Load Member
    246
    222
    Nov 9, 2013
    MID128 PID27 FMI13 translates to cummins code# 2348. That code is EGR valve position circuit - out of calibration. which means the EGR valve is failing the self calibration that it does every time the key is turned on and that you have either a faulty EGR valve position sensor or sticking EGR valve.
    Attached is the full fault code description.
    View attachment Code 2348.pdf
  4. Slow302
    348
    117
    Jul 12, 2013
    MO
    I understand its code for position sensor. But this only happens while im driving. Never when i turn key on/starting engine!
  5. Zusky407
    Zusky407 Bobtail Member
    32
    Jul 29, 2014
    Nebraska
    Try to unplug the motor for egr valve and test drive it to see for sure it is the valve. It will give you a code for unplugged egr valve but this way you can see if it is egr vslve for sure if it stops doing what it has been.
