New Mexico Scales
Discussion in 'Ask An Owner Operator' started by MRam0s, Feb 12, 2022.
  1. MRam0s
    MRam0s Bobtail Member
    Specifically, the scale house in Lordsburg, NM via I-10 West.
    Has anyone been put “Out Of Service” for using a mobile app (KeepTruckin).
    This week, my driver went from CA to TX to drop and on his way back TX to CA (I-10 Westbound) loaded with round trip load he was pulled in. He’s driving our newest 2500 Ram pulling a 15.9k lb derated gooseneck (NonCDL Hotshot) trailer and was asked to show his logs.
    There is no ELD unit installed yet since the truck is new and we’re waiting for the ELD unit to arrive, yet the driver was using KeepTruckin to record his logs and was compliant.
    The officer said he failed to show proof of logs because there was no physical unit attached to the truck itself yet he had his logs in “inspection mode” to provide proof.
    they made him sit for 10hrs and then allowed him to leave even though nothing changed because he left logging his hours on the same app that they said wasn’t sufficient proof.
    Has anyone experienced anything like this with this particular weigh station or any scale for that matter?
    very curious, email me if you’d like to discuss your experience directly.
    [email protected]
    Thank you!
  3. RustyRod
    RustyRod Light Load Member
    69
    104
    Feb 14, 2021
    Its not the weight station. To my knowledge, you are suppose to have an approved eld device connected to the vehicle even if you are using a mobile app. Off course just your app running is not proof of anything since it is not connected to the eld device that won't lte you cheat. You see now where the issue is?
    WildTiger1990 and justcarhaulin Thank this.
  4. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    The first thing is if I was going up against you & I stumbled across your statement "we are waiting for eld to come" then the truck is not road ready for lack of having eld.
    Every truck 2000 yr & up driving over 150 miles has to be eld complaint to operate. Your driver could get shutdown again or they could had made him sit until you had an eld installed. I would get that taken care of. It is on your inspection report each time they run your report.
  5. Vitkouski
    Vitkouski Light Load Member
    199
    279
    Mar 6, 2016
    KeepTruckin told me also that it’s ok to wait for the device for one month and using the paper logs at this time.
    No! I called local DOT and was told that I can use the paper logs max 8 days. After that 150 miles radius. Ordered another ELD.
    omardten Thanks this.
  6. brian991219
    brian991219 Road Train Member
    3,025
    6,217
    Aug 10, 2013
    Lords Valley, PA
    The Officer was 100% correct. A log app is not an approved alternative to an ELD, it would be just like using a paper log when an ELD is required. The Officer could have also written your driver for not being able to print on demand the logs, with a logging app they do not have to accept the inspection mode, despite what Keep Trucking claims, and can violate you for not being able to print.
    There is not exception to wait for an ELD to come in, the truck is not ready and properly equipped for service until the ELD is required. Now that your driver has been cited he will be allowed to complete the dispatched trip and return directly to the terminal but a functioning ELD must be installed prior to the truck being dispatched on another trip requiring a log book.
    Without an extension granted by the FMCSA you have a maximum of 8 days in any 30 day period to use paper logs in place of a malfunctioning ELD but no grace to place a truck into service before a functioning ELD is installed.
    Electronic Logging Devices | FMCSA
    ELD - Drivers and Motor Carriers
    The above two links are a bunch of general info and plenty of answers about the entire ELD compliance issues faced by carriers and this one answers your exact question ELD - ELD - FAQ Learn More scroll down almost to the bottom.
    Siinman and omardten Thank this.
  7. m16ty
    m16ty Road Train Member
    2,274
    4,964
    Jan 22, 2016
    I’m not so sure the officer was correct.
    We don’t have to run ELD because we normally stay within 150 mile radius, but are allowed to travel outside the 150 miles for no more than 8 days of a 30 day period. As long as the driver was out less than 8 days, and the truck was less than 30 days old, the short haul regulation would allow you to use paper.
    As soon as you pass the 8 day threshold within the 30 day window though, a ELD would be required.
    Accidental Trucker Thanks this.
  8. Vitkouski
    199
    279
    Mar 6, 2016
    • The HOS regulations do not apply to the transportation of agricultural commodities operating completely within the 150 air-mile radius by for hire or private carriers. Therefore, work and driving hours are not limited and the driver is also not required to use an Electronic Logging Device (ELD) or keep paper logs. In an operation where a driver uses a vehicle equipped with an ELD, a driver that is exempt can use an “Exempt Driver” account or annotate the time as exempt ag operation.
    • Once a driver operates beyond the 150 air-mile radius, the HOS regulations apply. Therefore, starting at the time and location where the transporter goes past the 150 air-mile radius, the driver must maintain logs using an ELD, unless the driver or the vehicle meets one of the limited ELD exemptions. The driver must work and drive within the limitations of the HOS rules when operating beyond the 150 air-mile radius. Time spent working within the 150 air-mile radius does not count toward the driver’s daily and weekly limits.
    ELD Hours of Service (HOS) and Agriculture Exemptions | FMCSA
    Siinman Thanks this.
  9. tiddlytanker
    tiddlytanker Light Load Member
    258
    783
    May 4, 2017
    Minot, ND
    I wonder why they make us carry backup paper logs "if our ELD breaks" if they are just going to make us sit 10 hours anyways.
  10. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    KeepTruckin will lie like there’s no tomorrow. I hate that about them, but they have the best product with the best customer service unfortunately.
    nikmirbre Thanks this.
  11. Short Fuse EOD
    2,791
    8,762
    Jul 29, 2015
    Midwest
    That is one of the reasons I don’t use them. Their customer service is a bunch of young folks trying to hustle on sales. Not much regard for your compliance.
