New Paccar DEF and boosting concerns...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Agtrucker, Oct 27, 2018.
  1. Agtrucker
    Agtrucker Light Load Member
    159
    47
    Dec 14, 2011
    Coming from a '14 mx 500 with 525000 miles that I was pleasantly surprised with coming from a 500 cummins before that.
    Recently got into a new pete with the mx-13, 510hp..Hoping it just needs to get broken in( only 7000 miles) but its been a slug so far, also dropping 2 injectors at 94 miles.
    Anyway this past week in 4 days I did 2300 miles burned 458 gallons of fuel and it took 25 gallons of DEF. I just looked up Paccar's estimate of usage which is 2-3 gal/def per 100 gallon/fuel. So I used almost doubled, pointed out to the shop how much I was using but it seem to fall on deaf ears only asking if I had any lights on.
    Is high def usage common when an engine is new? Kinda wondering if it's sluggish because its over dosing or whatever it does.
    Also I've noticed when pulling a hill (1500-1600 range) and around 35lbs boost it'll seem to hit like a dead spot in the power band, boost drops back to 30ish then spike back up and keep pulling up around 40lbs.. This all takes place in about 3-4secs.
  3. MACK E-6
    50,067
    238,727
    I’d definitely say you have something wrong there.
    My X-15 for example uses probably 9 gallons of DEF for about 200 gallons of fuel.
    Agtrucker Thanks this.
  4. Rn8806
    Rn8806 Light Load Member
    196
    272
    Sep 14, 2016
    Turn it in get a new one. Problem out of the gate.more to follow
    stwik and Agtrucker Thank this.
  5. roshea
    roshea Road Train Member
    DEF won't affect engine performance because it is injected into the exhaust stream typically several feet after leaving the turbo, into the SCR system. The only time it would interact with the engine is if it senses an error that should show a code/light, which will then lead to a derate. I have a DD-15 so can't tell you specifics on your engine but it should be about the same. EPA/CARB regulations mandate these "protections" to the environment, not DOT/FMSCA. So first it will derate your power about 15-25% and you will definitely notice that. If you don't get it fixed then within some timeframe that depends on usage it will limit you to 55mph. Ignore that and it will eventually limit you to 5mph, but usually (not always) that will happen when you stop and set the brakes, the system "assuming" you are in a safe place to be parked.
    If you dropped two injectors already there is certainly something wrong inside.
    larry2903, Agtrucker and daf105paccar Thank this.
  6. AModelCat
    164,842
    Aftertreatment and engine are 2 different systems but they work together. Many times people focus on the aftertreatment system when it acts up. What's upstream of the aftertreatment system? The engine. Any issues on the engine side can easily have an effect on the aftertreatment system. Just saying to look at the whole picture, not just the SCR system.
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    For comparison sake my 2015 isx cm2350 uses 4% def to diesel. Measured it several times and this is accurate.
    Unless the mx has its own emissions system now, I thought they were using cummins dpf and def systems.
    There is definitely something wrong internally, aside from the def usage. Separate issues would be my guess. Unless it's some kind of electrical issue. The bad thing about these new engines is if it thinks a sensor is bad it will prevent it from continuing on, putting you on the side of the road in the process.
    roshea and Agtrucker Thank this.
  8. archangelic peon
    archangelic peon Medium Load Member
    504
    376
    Dec 15, 2011
    I would be more concerned with getting 5mpg unless you just run West Virginia grades all the time...
    The DEF usage sounds alarming, but each manufacturer may have different ways to reach emission requirements, might be higher usage during break in for whatever reason, but should definitely get it looked at regardless.
    Boost pressure has a computer controlled wastegate so unless they program it to let off for whatever reason, you should be getting consistent pressure if the pedal asks for it.
    Maybe has something to do with EGT's, but then why spike up higher then before?
    All of these things combined sounds like a recipe for potential disaster down the road if not checked out, or at least saddling you with way higher running costs in the mean time.
    The only thing for sure is, from the various new trucks I have driven, none of those sound like 'normal' behavior at least from a Freightliner/Detroit perspective
    stwik, roshea and Agtrucker Thank this.
  9. uncleal13
    uncleal13 Road Train Member
    3,797
    6,299
    Apr 9, 2009
    Humboldt, Sk
    DEF usage also depends upon fuel consumption.
    I do about 2,000 miles a week. I use about 15 gal def per week in summer and over 20 gal def per week in winter.
  10. daf105paccar
    6,564
    7,294
    Apr 15, 2012
    What gross weight do you run at?
    What % off empty miles?
    When do you upshift or downshift?(rpm)
    DEF usage is linked to MPG.
    The lower MPG the higher the DEF usage.
    DEF usage has no influence on the engine performance.
    larry2903, roshea and Agtrucker Thank this.
