New radio
Discussion in 'CB Radio Forum' started by zaptear, Mar 2, 2013.
  1. zaptear
    zaptear Medium Load Member
    502
    171
    Nov 30, 2010
    vermont
    I don't understand how low gives me max watts and high is only 10watts
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  3. EZ Money
    EZ Money Road Train Member
    Kind of sounds reversed to me?....I'm not sure i understand what he wrote or he was thinking backwards.
    Ok.....looks like he set it up for low power to be a 2 watt dead key with 50+ PEP
    On high the Modulation is down.......?
    I would call and have him explain it.
  4. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    he is talking about deadkey, lo should be 2watt deadkey with 50+watt swing, more/louder audio, high should be 10watt deadkey with 50+watt swing, not as loud. If he knows what he is doing, run it on lo all the time and it wont matter if you are 2 ft away or 2 miles away it should sound the same as far as clarity, and loud.
  5. country29
    518
    157
    Feb 27, 2010
    I think he said something about swing kit, if so it may not be as clear close to someone on low power. I dont believe in swing kits, that radio can be tuned without adding a bunch of junk to it. but his swing lit maybe something other than what i know them as, plug it up, try it out and see what it does.
  6. zaptear
    502
    171
    Nov 30, 2010
    vermont
    Monday a coworker that knows what he is going to tune my antenna and install the radio I will let u kmow how it dose
  7. zaptear
    502
    171
    Nov 30, 2010
    vermont
    Ya I called him its 10 watt dead 50+ on high and 2 watt dead 50+ on lo he said run low all the time high if at a truck stop our running with someone
  8. zaptear
    502
    171
    Nov 30, 2010
    vermont
    I also got browning rg-8/x coax he told me that was good
  9. Voltrucker
    Voltrucker Medium Load Member
    467
    133
    Sep 24, 2012
    West TN
    I'd run it on low at ALL times! 10 watts deadkey is too much. 2w is just right.
  10. MsJamie
    MsJamie Road Train Member
    I'd love to see how nasty that 2:50 swing looks on a spectrum analyzer. I'd be surprised if he's putting 10-15 watts in channel. The rest is getting splattered all over the place.
    That's probably why the instructions say to use the 10W setting for local use. The splatter is likely blowing through the filters in the front end of the local receivers, making the signal sound worse.
    EZ Money and n9mxq Thank this.
  11. zaptear
    502
    171
    Nov 30, 2010
    vermont
    He says I will put out 57 watts we will see my coworker has the meters he knows his stuff I will let you know when its up and running
