New to me Pinnacle
Discussion in 'Mack Forum' started by Sledneck32!, Jan 25, 2017.
  1. Sledneck32!
    Sledneck32! Bobtail Member
    32
    32
    Jan 18, 2017
    Well just signed the agreement on a 2013 cxu613.
    450,000 miles
    M Drive
    Mp8 445hp
    $42,000
    Plan is to daycab it, stretch frame from 221" to 270" roughly. Install 24' van body with small crane, stairs, toolbox and vise on remaining 2' of Frame. Will be used for vocational work lining manholes. Heavy duty Industrial painting. This is my first truck. Very nice shape cosmetically inside and out. How did I do? Didn't really get any wiggle on price, but very nice and patient salesman who's spent at least 12 hours so far teaching me about trucks and answering noob questions.
  3. Sledneck32!
    32
    32
    Jan 18, 2017
    Pics/specs attached
  4. Sledneck32!
    32
    32
    Jan 18, 2017
    Does anyone know what it would take to beef up the front end on this truck? I'm running into weight issues, with only being able to have 34k on the drives here in MN. Need to transfer more weight to the front but with just the van body alone that will almost have the front end at 11,500 lbs. Then I need to put 20,000 pounds inside the van body and thinking that might be too much for the front axle?!
  5. crb
    crb Road Train Member
    1,676
    1,374
    Dec 1, 2009
    USA
    Should have bought the truck for the job honestly. Beefing up front axle is gonna mean replacing it which means being re certified with new weight rating. From the sounds of it you should have bought a vocational trype truck not a road tractor.
  6. Sledneck32!
    32
    32
    Jan 18, 2017
    I haven't technically bought the truck yet. I have money down on it, but if need be I can switch to something else. Is getting re-certified fairly common? Mainly I'm wondering about parts "swappability". Can I just put in heavier leafs to get to say 13,200 or 14,600 FA? Reason I ask is because there are a lot of identical tractors for sale with 14,600 FA ratings. It may just be a leaf/tire swap?
    There are very very few vocational trucks with tandem axles and the other stuff I need. The only ones I found were literally worn out. Which is why I am trying to build one somewhat newer that will last me 10 years. As opposed to buying one that already has 10 years worth of wear on it.
  7. crb
    1,676
    1,374
    Dec 1, 2009
    USA
    Not sure how involved it is to up fit to heavier axle rating. I would talk with dealers shop or frame shop that you plan to use for stretching it they should be able to help.
    Will you be using this off road?
    If so I would want a double frame.
    Would adding a steerable pusher be an option instead of upgrading steers?
  8. Cat sdp
    Cat sdp . .
    21,340
    76,518
    Apr 8, 2012
    Orion's Belt
    My guess is it's more than springs/tires....
    Another Canadian driver and crb Thank this.
  9. Ridgeline
    22,794
    125,117
    Well here is the deal.
    First off you need to find another truck. This one would be ok but it would be better to find something spec'ed for the job.
    Second by the time you add in the additional costs of a higher capacity axle, and tires, you will also need to make sure it a double frame if you are talking about the weight you are, plenty of vocational trucks out there that will meet this without difficulty finding them.
    Also do not buy a truck blind, go through your due diligence to make sure it is actually worth the money. This isn't a pickup truck.
  10. Cat sdp
    Cat sdp . .
    21,340
    76,518
    Apr 8, 2012
    Orion's Belt
    If this is a volvo/mack dealership they should have access to lots of chassis that would do the job....
  11. Sledneck32!
    32
    32
    Jan 18, 2017
    The axle itself is rated 12,000-14,600. Basically its the same axle for both ratings. The key is figuring out which parts need to be switched. The dealers shop is working up the details, but offhand they think it can be switched over for a few thousand dollars.
    This will not be used off-road. Adding a steerable pusher is definitely an option, but I guess in my mind it just seemed like that would be more work/headache that just getting everything to work with what I got so to speak.... The salesman did mention that I may have to run a pusher axle, just debating which is the route to go.
