New trailer GVWR
Discussion in 'Expediter and Hot Shot Trucking Forum' started by midcon, May 25, 2020.
  1. midcon
    midcon Light Load Member
    61
    206
    Apr 11, 2020
    I have a new trailer on order being built with 16k rated axles and a plated GVWR of 40k. This will incur the 12% FET which is a substantial amount on an already expensive trailer. So my question is if I have the builder derate and drop the plated weight down to 25,900 to avoid the FET will I be giving up the extra load capacity or can I still take full advantage of the 16k axle ratings? I haven't talked to builder yet but I assume that the axles would still be rated at 16k each on the plate even though the GVWR has been reduced. Hope that makes sense.
    singlescrewshaker Thanks this.
  3. longhaultransport
    longhaultransport Light Load Member
    205
    548
    Dec 25, 2009
    West Central, Florida
    I would like to know the answer as well.
    All I have ever heard was the legal rate is the derated weight, but DOT only looks at tire rating, and not the data plate on the trailer to determine if you are overweight or not.
    For example, if you are trying to stay under CDL, derate the trailer with 2-7000 lb axles to 12,000 to stay under 26,000 gvwr, the DOT will accept that, but you can still put 14,000 on the axles for scale weight.
    DOT only looks at tire rating and registered weight to determine what your gvwr is, not the data plates.
    I don't know the facts about that, only people talking about it.
  4. midcon
    61
    206
    Apr 11, 2020
    Same here. I have read everything I can find and talked to some O&G hot shot guys but no one can give me a definite answer. Here is an example from a new trailer with 12K axles for reference. So if I had the 16K axles de-rated to 25900 GVWR would I be limited to the 25900 or the 16000 x 2 which the axles are rated for? The sticker on the right would be MIA on trailer delivery weight sticker1.jpg
    clausland and singlescrewshaker Thank this.
  5. singlescrewshaker
    4,888
    42,841
    Dec 31, 2017
    Little Havana, FL
    All depends on how smart the law dog is inspecting you..
    25999 GVWR means just that. Is it safe to load 32k on a tandem rated for it. Sure. But you gotta pay to play if you want to do it legally..
    Had one in new York state check the BOL weight against my sticker once. All it takes is a wee bit of arithmetic, & your OOS..
    clausland, AModelCat and midcon Thank this.
  6. midcon
    61
    206
    Apr 11, 2020
    Thanks a lot. I was hoping you would chime in. I guess I'll pay the tax with a smile because with my luck I'd get the smartest officer in the state on every stop. The upside is at least its another tax deduction.
  7. singlescrewshaker
    4,888
    42,841
    Dec 31, 2017
    Little Havana, FL
    It sucks no doubt, but you'll be happy later you are not constantly looking over your shoulder when heavy. You may get away with it?, but I sure won't. I seem to get caught anytime I deliberately try to get away something. On honest mistakes, I've been cut some slack, not much, but I must have the deer in headlights look about me that let's them know it was an honest mistake. LoL.
    I had to give away $5160 in FET on my new stepdeck. No fun..
    I also had one measure the trailer spread once in Mt. Airy NC. I'm sure you'll have at least 48" axle spread so you'll be fine, but the minimum is 40" or its still considered a single & only good for 20k lb.
    What I've found is each officer has one special little thing they like to target. Be it weight, logs, axle spread, tire ratings, break away battery, they each seem to hone in on one thing, at least in my experience so far..
    clausland and midcon Thank this.
  8. midcon
    61
    206
    Apr 11, 2020
    Yeah I went with 72" axle spread for better weight distribution. I'm sure I'll have that deer look myself on a regular basis. So much has changed in the industry since my log hauling and heavy equipment transport days 25 years ago back in East TX.
  9. singlescrewshaker
    4,888
    42,841
    Dec 31, 2017
    Little Havana, FL
    Oh yeah, 72" should ride a little nicer too from what I hear. You'll probably never have the axle spread examined, very easy to visually tell 6' is way more than the 40" minimum..
    Oh wow, have you been off the road for 25 years?
    I'm thinking the most annoying part for you will be ELD's, unless you're going to be running in one of the exempt categories.
    That is one, among a few other reasons why I chose to start running an older tractor. After a couple years in the semi, I figured why am I still pulling a gooseneck, limiting myself to less freight. Lots of full 48' loads that are still light weight..
  10. midcon
    61
    206
    Apr 11, 2020
    Yeah I've been out for 25 years. I started driving when I was 16 in the summers with my dad who drove a truck his whole career. Had my CDL since I was 18 and paid my way through 5 years of college hauling logs and logging equipment. I have kept up my CDL all these years as I always wanted to get back into trucking some day.
    The ELD is definitely going to be a pain as all I know is run till you can't then run some more. Although at 52 I wouldn't hold up very long to that anymore. LOL
    I opted to go this way so I can do things when I'm out on the road that would be harder to do in a big truck. Although, I'm sure I'll do something similar to what you're doing one day, and if the ELD is a real PITA it might be sooner rather than later. Paper logs give you so many options.
  11. Slay
    Slay Light Load Member
    132
    137
    Jan 7, 2015
    The poster that says the DOT man only looks at the axle and tire ratings has been lucky at best. Every time I have been pulled over they look at the sticker in the truck door and the sticker on the trailer. I had my trailer derated to allow me to run under 26000. 11,400 for the truck and 14,500 for the trailer.
    Second I would not remove the sticker from the trailer. Without it he does not that you have 16, 000 axles and put you OOS for the lack of information. Also I believe removing a VIN from a vehicle will result in a trip to jail. How else does he tie the info and trailer back to you? Are you dragging a stolen trailer?
    singlescrewshaker and midcon Thank this.
