New truck specs.
Discussion in 'Ask An Owner Operator' started by SoulScream84, Jan 12, 2021.
  1. SoulScream84
    3,458
    26,578
    Mar 21, 2020
    Maybe this has been addressed recently, but when I've searched these items the posts were relatively outdated. My first question aside from brand loyalty why do some of you prefer either Detroit or ISX Cummins? Secondly, where is the best source to research axles? Available options are the Detroit, Meritor, or Hendrickson. Yes I'm specing a Cascadia rather than Pete or KW.
    Despite the hate the plastic gets, I've seen them do well even with the crappy maintenance programs of large fleets, so it stands to reason that at a lower cost they should be more profitable than paying for style.
  3. Brandt
    Brandt Road Train Member
    4,632
    6,368
    Sep 17, 2012
    Detroit engine are good but have trouble will emissions box at about 600,000 miles. Cummins is good but had problem with fuel pumps going bad in first couple year ISX come out. They had oil problem with top cams shafts going bad. They have trouble with carbon build up inside piston rings and stuff. So no perfect engine today
    TallJoe and SoulScream84 Thank this.
  4. Spyro2112
    Spyro2112 Medium Load Member
    625
    434
    Mar 17, 2018
    X 15. Henderson
    D.Tibbitt and SoulScream84 Thank this.
  5. SoulScream84
    3,458
    26,578
    Mar 21, 2020
    Any particular reason on the axle choice? So far the only accurate information I've found differentiating them is that the Detroit is supposed to be a better turn radius, and better performance using a Detroit engine/trans/ axles combination.
  6. Cat sdp
    Cat sdp . .
    21,318
    76,328
    Apr 8, 2012
    Orion's Belt
    If your going FL just keep everything in-house so there’s less reps to deal with.......
    Bean Jr. Thanks this.
  7. SoulScream84
    3,458
    26,578
    Mar 21, 2020
    Right now I'm working on research, waiting to see how the market plays before I commit to a purchase.
  8. slow pok
    slow pok Light Load Member
    144
    212
    Oct 27, 2013
    lizela ga
    Ft is better than kw the last few kw where in the shop every month not with this ft not at all in the past yr it’s a 19 with a dd12 auto
    77fib77 and D.Tibbitt Thank this.
  9. Midwest Trucker
    5,914
    21,390
    Aug 31, 2018
    KW T680 Cummins X15 efficiency 450hp. Endurant 12 sp auto trans. 230 inch wheel base. 2.79 gears. Get heated fuel tanks for in the winter unless you only run south.
    Crude Truckin', bzinger and TallJoe Thank this.
  10. TallJoe
    TallJoe Road Train Member
    7,490
    16,273
    Apr 12, 2016
    Chicagoland
    Do you track mpg on this one so far?
    Midwest Trucker Thanks this.
  11. TallJoe
    7,490
    16,273
    Apr 12, 2016
    Chicagoland
    Would I be correct presuming that a gear ratio, other than 2.55 - 2.79 (which works good in the Midwest for the most part) for rather sporadic excursions over the Rockies, say climbing up there up to 10 times a year on I - 80 or I -90 going to West Coast and back - and assuming to be on a heavier side 75 - 80K lbs, should not matter much?
