New trucker at a loss .
Discussion in 'Questions From New Drivers' started by Hotshot2trucker, Feb 6, 2019.
  1. Hotshot2trucker
    Hotshot2trucker Bobtail Member
    26
    4
    Jun 8, 2018
    Can anyone tell me how I can find out what hp and torque my truck is running at . I have 2013 volvo vnl 630 . 500hp 1750 torque 355 rears and a 13 speed eaton fuller. I'm about to add a dual line wet kit but some times when I pull 100k it has some struggle especially up any kind of incline . I read somewhere that the truck warranty will cover more when its turned down to 425hp and the truck was a lease at volvo .
  3. Roberts450
    Roberts450 Road Train Member
    2,237
    3,638
    Feb 6, 2016
    Find a truck dealer that has a dyno and have them dyno it, that will tell you what its putting out at the wheels.
  4. Hotshot2trucker
    26
    4
    Jun 8, 2018
    Where would I find a dyno for big trucks in Louisiana. Will a dump for cars work with a big truck . And can they tell me what the torque is at too .
  5. Hotshot2trucker
    26
    4
    Jun 8, 2018
    I meant dyno but the dumb spell check put dump .
  6. Bill51
    Bill51 Road Train Member
    1,185
    2,982
    Jul 27, 2015
    Why go through that trouble? Can't the Volvo tech just hook up the laptop and see what it is set at?
    x1Heavy Thanks this.
  7. Hotshot2trucker
    26
    4
    Jun 8, 2018
    They said that they can't , or won't . They said something like what you said about the dyno but didn't say where I might get it done . Volvo' s head tech just changed and I don't have any dealing with him like I did with the previous one .
  8. Roberts450
    2,237
    3,638
    Feb 6, 2016
    He could but sounds like he is complaining of low power so if jts not performing as the 500hp the computer or sticker says then a dyno test will show that.
  9. Roberts450
    2,237
    3,638
    Feb 6, 2016
    Has to be a dyno for big trucks. Look up the cat or cummins dealer in your local area as most of the time they have a chassis dyno or they will know where to send you.
  10. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,144
    Mar 5, 2016
    White County, Arkansas
    And anything with 100K on the entire rig gross weight will struggle at some point upgrade of any kind.
    We do not run 750-1200 HP like the Europeans do. Most we generally get out of company trucks is 500 HP give or take. Has been this way for oh... 30 years now. Torque is going to max out at 1850 generally, no more than that unless it is special tuning for fire trucks etc for 2050 and up in torque to drive the pumper and other apparatus. 1650 to 1700 is pretty common. (It's weak, but better than nothing)
    If you had a older 450 HP engine then it's REALLY going to give you less performance upgrade. You would be more concerned with Mr Pyrometer getting too hot and burning something out. I put a 350 cat at 80000 against a 20+% out of ethan allen once with hardwood furnature and it's speed was less than walking pace on that 3 mile pull. Took a hour and change to get up there and two plus to cool off down to normal.
    I don't know anything about engines newer than 2001, but you definitely benefit from engines that are capable of getting to around 2150 red line and not castrated to 1900 or so. Provided Mr Pyrometer will let you do it.
    It's not so much the upgrade, 100K will slow you down anyway. It's the getting down that seperate real drivers from wanna bes.
  11. Hotshot2trucker
    26
    4
    Jun 8, 2018
    Thanks I'll try that . The volvo tech said he could do a overhead valve adjustment . Don't know when it was done last but some say should have it done at least every 200k miles .
