Hello all,
I'm a newbie driver and needing some help on where to purchase a self adjusting antenna.
Thank you,
Mighty Mouse.
Newbie Driver needs cb/self adjusting antenna
Discussion in 'CB Radio Forum' started by MightyMouse75, Jan 17, 2019.
pre-adjusted or rather adjusted at the factory are Francis antenna's.
i have used them and like them,. and they are not too expensive. -
Self adjusting antennas get expensive. First you would need a controller.
TuneMatic
Then the antenna.
Tarheel Antennas - Home
Much cheaper to buy a cheap cb antenna.
5.5' Francis Black Hot Rod CB AntennaDiesel Dave Thanks this. -
What is a self-adjusting antenna??
InTooDeep Thanks this. -
I had one that adjusted itself to the proper height after it smacked a 13-6 bridge
My Screwdriver, covers 3.2 MHz-28.0 MHz. Not tried on CB but I'm sure it would work fine. On 27 mhz I use a Francis 5 footer.rabbiporkchop Thanks this.
A misnomer. Needs a controller to work.
TuneMatic is a self-contained antenna controller which automatically adjusts the resonant frequency of a screwdriver/motorized antenna. TuneMatic operates anywhere between 1-60 MHz, and supports a wide variety of screwdriver-type tunable antennas. TuneMatic utilizes frequency measurement, SWR detection, and antenna position to perform the proper tuning, and stores the tuning data in a series of internal reserved memory banks, based on frequency and bandwidth. The TuneMatic is independent of rig make and model and will typically support any HF rig with a PTT control line. TuneMatic is supplied with a backit wired remote button panel, which contains all the functions necessary to operate TuneMatic from the driver’s seat. -
Come on guys, I know what it is, it is a rhetorical question - what is an auto-adjusting antenna?
Tunematic is ok but without knowing where the antenna is in its resonance, it is useless - too much hunting.
By the way, I use one of my screwdriver antennas on 27mhz, it works just as well as expected. -
On a big truck? No snark, but wondered how/where mounted.
Anything is possible with some creative engineering.
Crude Truckin' Thanks this.
