Newer Cascadias Opti Idle System
Discussion in 'Experienced Truckers' Advice' started by CorsairFanboy, Dec 31, 2024.
  1. CorsairFanboy
    CorsairFanboy Medium Load Member
    610
    1,035
    Feb 19, 2018
    How do you guys sleep/put up with that system? It seems like torture/inhumane to me. That thing beeping, then starting the truck, going all the way to high idle (1000 rpm) and running for a few minutes.
    writing this, parked next to a few trucks with that system. Why do guys put up with that? What happened to the diesel APUs? Why are companies cheaping out on those now?
    Iamoverit Thanks this.
  3. TX2Day
    TX2Day Medium Load Member
    612
    4,098
    Apr 24, 2023
    Texas
    Cheaping out? $20,000.00 for a product that may or may not be reliable is not how I would want to spend my money. Using the opti-idle allows for more functionality at a greatly reduced cost when paired with the auxiliary heater. With that said there are settings on the opti-idle (That the shop has to adjust.) that will increase the drivers comfort.
    As for your comfort trying to sleep next to them, sorry about that. Park somewhere else? I try to get parked next to a non-APU, non-reefer when I have to park at a truck stop. That usually works the best for me.
  4. CorsairFanboy
    610
    1,035
    Feb 19, 2018
    I’m asking how do people sleep with the truck constantly turning on/off? Its very disruptive. I remember when I did reefer I could feel when it went on/off. The truck on/off is worse.
    Heck, last time I drove a cascadia, we could straight idle, but when it did the parked regen it was very violent.
    Rpms would go up to 1300 and the whole truck would shake/vibrate like it was going to fall apart.
  5. TX2Day
    612
    4,098
    Apr 24, 2023
    Texas
    Got me, I pull a flat or a van most of the time. When I do pull a reefer I can disconnect from it and not have to listen to it all night.
    I always tell newbies to check what sleeping systems are on the truck. It is a big deal for many people, others, not so much.
    A couple newbies I know bought a portable AC unit for the summer and use the auxiliary heater for the winter. So very little fluctuating noise and shaking of the truck. With that said, they learned from me where to park and where not to park.
    CorsairFanboy Thanks this.
  6. OldeSkool
    OldeSkool Road Train Member
    2,136
    7,073
    Jul 17, 2018
    New Hampshire
    You just have to get tired enough. Anyone that has trouble sleeping just needs to drop back to 4-5 hours a night. That has a way of fixing it really quick.
    D.Tibbitt Thanks this.
  7. CorsairFanboy
    610
    1,035
    Feb 19, 2018
    I agree with your methods. I use them myself. This truck im driving now doesn’t have an aux heater unfortunately, so I do idle when its really cold. I would love it if it had an esbar heater. I prefer not to idle. Thankfully the regen on this cummins is not as violent as the cascadia.
    It just pains me to see where the industry is headed. And we just keep on putting up with the abuse.
    I myself think that opti idle system is inhumane and borderline torture device. From what Ive seen so far. I would try as much as possible to avoid driving for someone who has a truck set up that way.
    Either put an apu, or let me straight idle at my discretion (old school way). I am not an over idler but I want comfort/consistency. I think it is a fair ask. Specially after driving 700ish miles.
  8. CorsairFanboy
    610
    1,035
    Feb 19, 2018
    That’s a great attitude, the one that has allowed us to get to this point.
    “please sir, may I have some more?”
  9. Brandt
    Brandt Road Train Member
    4,658
    6,455
    Sep 17, 2012
    My company has the opti idle but they also have the 8 batteries powered a/c and heater. So you can run on batteries all night when sleeping
    Hatt91 and hope not dumb twucker Thank this.
  10. LOTSO
    LOTSO Heavy Load Member
    906
    2,198
    Mar 28, 2023
    My APU got a hole in a A/C hose, so I had to use Opti-Idle during the daytime for 2 weeks in the 100's in August. It saves at least 50% idle time, so I can see why fleets want you to use it. It came on for 12-15 minutes and would shut off for 15-20 minutes. That's worst-case scenario. Never have used it in the 90''s but it would only run less obviously. It's like the one gentleman said, "If you're tired enough you will sleep through the Start/Stop shake and noise" It's not as bad as the guy with the purging air spitter, but what is...:dontknow:
    hope not dumb twucker Thanks this.
  11. Brandt
    4,658
    6,455
    Sep 17, 2012
    Another driver I know who owns his truck. Got a new truck and put on new Thermo King apu. He said it was $14,000 so they are not cheap today. My computer truck with 8 batteries a/c and heater can go 10 hours then the opti idle will start engine to recharge the batteries for 2 hours. It’s good when sleeping but not big enough to A/C the front and sleeper. The heater works good but when you start getting to 5F and colder it has trouble keeping up. It also heats the coolant to keep engine warm.
