Night time down grades.
Discussion in 'Questions From New Drivers' started by Canadianhauler21, Jul 18, 2018.
  1. Canadianhauler21
    Canadianhauler21 Heavy Load Member
    864
    1,639
    May 15, 2017
    I realized sometimes at night I have a hard time identifying short downgrades. Like my truck is governed at 63MPH, I'll be running down somewhere in PA and I'll look down at my speedometer and boom 73MPH. I'm super micro managed so when I go over 70MPH it sets off a "critical event warning" and I have to hear all about it from the safety guy at the end of the month. I run strictly nights, and sometimes days. Day times I have no problems identifying these down grades. I have had 19 "critical event warnings" (overspeed) in my first month of driving. All of which happened after sunset.
    Any tips on noticing these down hills/downgrades at night?
    I'm a rookie so don't pound me ;)
    Lepton1 Thanks this.
  3. Lab work
    Lab work Medium Load Member
    551
    674
    Apr 20, 2018
    USA
    Yea I have done that also. Kind of strange sometimes the lack of warning signs. Usually if possible I shine the bright lights when it doesn't interfear with traffic. It helps sometimes especially if I am not used to the route.
    Oldironfan and Canadianhauler21 Thank this.
  4. TripleSix
    133,017
    If your truck has a Smart Jake, see if they will set it up so that, if you're on the cruise, it kicks in stage 1 at 3 over the set speed
    Lepton1, not4hire, TravR1 and 3 others Thank this.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Turn on engine brake with your cruise, it should engage at maybe 3-5mph above whatever your cruise set speed is at.
    If you aren't that far over the limit tell your company to piss off. If it's 73 in 70 just for the downhill that isn't that big of a deal.
  6. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,544
    May 22, 2017
    Say its dark out. Ask if the boss wants to do your job. And then hammer down.
    Lepton1, not4hire, Woodys and 4 others Thank this.
  7. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Turn off or lower all your electronic gear and listen to your engine. If you're not running against the peg then you should hear a difference. If you are running up all the way just back off a tad bit and you'll hear it.
  8. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Tell them the governor must be set wrong. If there's no warning signs they can sneak up on you sometimes, you get dummies like me will use rolling a little faster downhill to get better mileage, the one run I do a lot I can do between .25 and .5 better a gallon and go faster, you have to know where you can pull it off though.
  9. SteveScott
    SteveScott Road Train Member
    4,897
    16,809
    Nov 10, 2015
    And yet another reason I don't drive at night. Yes, judging gradual grades in the dark can suck.
    Canadianhauler21 Thanks this.
  10. Oldironfan
    5,776
    5,544
    May 22, 2017
    Brakes are for deleted.
  11. Moose1958
    Moose1958 Road Train Member
    15,283
    33,921
    Dec 17, 2010
    Williesburg, Virignia
    I will try to be gentle with my pounding. I'm assuming you are operating an automatic transmission. Since your talking about operating in mountains on cruise. I'm also assuming since it is nighttime you are also driving with music blasting or at a medium level. Ok fair enough. These events are not being caused by those downgrades. Sorry hand their being caused by your lack of sensory feedback to your engine RPMs. Your going to continue to get these things until you break that habit and pay attention to your Tach and your engine. There is no simple way to do this. In time when you get more experience with these highways you can relax a bit. Till then I highly recommend you shut off that music or see about getting into a 10 speed.
