Nitrogen filled tires...
Discussion in 'Trucks [ Eighteen Wheelers ]' started by southerndude, Sep 29, 2012.
Your thoughts on nitrogen filled tires (NFT)
  1. *
    I have NFT to save money
    3 vote(s)
    17.6%
  2. I will never get NFT...Too expensive to implement
    9 vote(s)
    52.9%
  3. I am and O/O and want to lear more about NFT
    5 vote(s)
    29.4%
  4. What is nitrogen?
    0 vote(s)
    0.0%
  1. southerndude
    southerndude Light Load Member
    66
    41
    Sep 1, 2012
    SC
    Ok... I searched to see if anyone has already asked this question and I have not found it.
    Nitrogen gas filled tires seems to be a very good way of increasing overall fuel mileage as well as extend tire life dramatically.
    All you O/O out there... have you switched over to NFT (yet another acronym) and if so, what was your reason and what was your cost?
    If not... why not?
  3. 55_cans
    55_cans Light Load Member
    98
    19
    Sep 14, 2012
    Alberta
    Just wondering how it does this and how much it impacts mileage and tire life?
    Is it because of being lighter than air, or other?
  4. Smellfunny
    Smellfunny Road Train Member
    1,446
    968
    Jan 28, 2012
    South Carolina
    When I bought my used Toyota Tacoma the tires were filled with nitrogen. Unfortunately the town I live in no one supplies nitrogen. So when my low level indicator came on I had to add regular air. Just installed new tires and I am back to air. I would prefer to run nitrogen but unavailability kills it for me.
    Here is an article on it. http://www.popularmechanics.com/cars/how-to/repair-questions/4302788
    55_cans Thanks this.
  5. southerndude
    66
    41
    Sep 1, 2012
    SC
    Only a small percentage of the air we breathe is made up of oxygen. 78% of the air we breath is made up of nitrogen. Oxygen expands and contracts much more than nitrogen. If you got rid of the expanding and contracting by filling your tires with 100% nitrogen, they will stay at proper preasure longer, in cold and in heat. Your tires last longer, you get better mileage.
  6. 55_cans
    98
    19
    Sep 14, 2012
    Alberta
    Thanks for the article. Did not know about migration through rubber. Did not think about internal pressures based on nitogren being more stable with tire temperature changes.
    So the $$ savings in mileage and tire life is basically based on the fact that a nitrogen filled tire is more apt to provide better internal pressure stability because it is dry gas (zero water content) and is not impacted as much by temperature changes.
  7. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Several years ago i helped out a guy with his car at a local race track. Nearly all the cars run nitrogen in the tires. Handling can change with 1 psi change. As has been said, the nitrogen is much steadier psi. So it is a way to help keep handling more predictable, on the track.
  8. Cat sdp
    Cat sdp . .
    21,322
    76,372
    Apr 8, 2012
    Orion's Belt
    Told my local bridgestone dealer I wanted nitrogen in my new tires. He laughed at me. For what new rubber costs we should have the option.
  9. southerndude
    66
    41
    Sep 1, 2012
    SC
    Has anyone paid money to a shop to "switch" out their regular air for nitrogen or have heard of a place that does it for $XX? How much did you pay to have it done?
  10. Dieselwrangler
    Dieselwrangler Light Load Member
    128
    92
    Oct 16, 2011
    Edmonton, AB
    I read a posting a while back where the guy figured after a few top-ups, the tire is pretty much nitrogen filled any way. His reasoning was, after the 22% of small molecule gasses seeped away through the casing, 78% of the 22% top-up was nitrogen. After a few top-ups the 22% would be such a small amount of the total, that it would be virtually nitrogen filled.
  11. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Costco will do car tires, not sure about large cars.
