No ac in cab, but works in sleeper
Discussion in 'Volvo Forum' started by 4wheelBoater, Jul 29, 2019.
  1. 4wheelBoater
    4wheelBoater Bobtail Member
    5
    Jul 29, 2019
    2007 Volvo vnl 670 w/D16. Lost blower function in the cab. Diagnostics is showering stepper motor electrical fault on all 4 phase and a 5v supply electrical fault. When idling there is no air and when driving it blows gently. Any idea if it would be the switch or the blower?
  3. boneebone
    boneebone Road Train Member
    2,298
    2,373
    Mar 13, 2009
    Run a set of jumper wires to the blower motor and see if it spins at full speed, if it does the switch is the problem.
  4. KB3MMX
    KB3MMX Road Train Member
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    You can plug in a new blower control module to test. If that doesn't work it is probably the blower motor itself.
    Takes about 45 mins to fix
  5. 4wheelBoater
    5
    Jul 29, 2019
    A new control module is around $400, that’s an expensive “test” if that isn’t it. Just thought maybe someone had had this happen before and would have a heads up
  6. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Mine was doing the same thing, so I went for the low hangin' fruit and replaced the blower and module at the same time seein' as I had everything apart. Blower was 160 bucks I think and the module was 65. Works fine now.
    KB3MMX Thanks this.
  7. KB3MMX
    3,079
    2,596
    Dec 29, 2014
    Orrstown, PA
    $60-70 , I keep a spare
    Friggin easy to check too
    d281833 Thanks this.
  8. VolunteerTrucker
    VolunteerTrucker Light Load Member
    166
    104
    Dec 8, 2014
    What did it end up being I’ve got the same problem, thought it was the blower
  9. Burdisco
    Burdisco Light Load Member
    121
    53
    Apr 25, 2015
    Hi, Cold in the bunk but coolish in cab - change expansion valve. Total pain! Blower motor not blowing fast -check the wires at the resistor, that is attached to blower motor. I had to change the connector to lucar connectors, size .101mm 14 gauge with heat shrink on each terminal. .101 mm because they are tight. Blower now works great!
    VolunteerTrucker Thanks this.
