No accelerator response randomly.
Discussion in 'Volvo Forum' started by Rogee, Mar 17, 2021.
  1. Rogee
    Rogee Bobtail Member
    4
    4
    Mar 11, 2021
    I have a VOLVO D13 I SHIFT WITH 600000 MILES. RECENTLY the TRUCK STARTED TO completely LOSE POWER while driving along the road AND JERKS ERRATICALLY when trying to move again, KIND OF LIKE I am PUMPING The accelerator PEDAL LIKE CRAZY. IT ALSO HAPPENS ON CRUISE CONTROL. Also if using the engine brakes they will just shut off and truck will coast to a stop. Sometimes happens when moving off from a stop where the truck will just jerk rapidly as it starts and stops. If gear shift is placed into neutral and accelerator is pressed down the engine just revs up then cuts back out continuously. Volvo agent ran diagnostics and showed clutch and transmission still has good life remaining but a fault showing in the electrical part of the i-shift. I have taken the truck to there workshop where they have been working on it all week but haven’t yet found/ fixed the problem. Has anyone experienced this similar problem before and what was the fix. Thanks
  3. Eddiec
    Eddiec Road Train Member
    2,327
    3,584
    Feb 2, 2015
    Check the throttle positioning sensor
  4. Petro51
    Petro51 Bobtail Member
    5
    Mar 18, 2021
    Could be bad turbo actuator , harness,vanes stuck with carbon, worn out sector gear or out of calibration.
  5. Nubb909
    Nubb909 Bobtail Member
    21
    8
    Oct 23, 2016
    Danville va
    Ive had something simular more or less... mine had some broke/cracked electrical lines on the turbo
  6. Rogee
    4
    4
    Mar 11, 2021
    Problem solved by Volvo agents, diagnostic showed solenoid or sensor problems in i-shift, the top of transmission was removed and ribbon cable and a solenoid controlling the splitter gear of the transmission was replaced. No problems since.
  7. Amon12345
    Amon12345 Bobtail Member
    Aug 4, 2022
    How much did it cost parts and labor?
