no breaks on trailer ticket
Discussion in 'Trucking Industry Regulations' started by No5id3Fried, Nov 30, 2011.
  1. No5id3Fried
    No5id3Fried Bobtail Member
    42
    7
    Sep 13, 2010
    Sacramento Ca
    I got a ticket for no brakes while going through the banning scales in california,i was driving a ford F550 pickup and hauling a bobcat on a trailer with electric brakes,the guy tried to give me unsecured load,low brake fluid ,trailer hitch worn,and brakes not working ,but the chp only wrote me for the brakes not working,i also had to have the traier towed back to the yard on a flatbed,when i got to the yard i found out the brakes worked and all it was was the gain was at 5 and it should have been at 9,is there a way to fight the ticket or should i just pay it?also a coworker said i should just go by the scales since im in a pick up.
  3. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    Depending on what the sign says. If its all trucks over xxxx lbs, than you must pull in. The DOT has no sense of humor for (real or perceived) scale dodgers.
    You should definitely fight that ticket. Though checking the power level of your brake actuater should be something that is done frequently.
  4. Allow Me.
    10,783
    12,641
    May 28, 2009
    Rancho Mirage, Ca.
    Ca. scales almost always say "no pick-ups". Not sure if that's that particular scale or some of the signs have been knocked down and not replaced.
  5. shredfit1
    shredfit1 Road Train Member
    1,290
    583
    Nov 24, 2008
    MN
    Yes fight the ticket...
    Secondly, how do they know the brakes didn't work? My best guess is that they checked the emergency battery and break-away on the electric trailer breaks. And if neither were there, or battery was dead, they write you a ticket... even if the brakes do in fact work.
  6. Scalemaster
    Scalemaster Heavy Load Member
    808
    1,717
    Mar 13, 2011
    Midwest
    If the emergency breakaway system does not function properly, that in itself could be a ticket. It would be an out of service violation.
    dieselbear Thanks this.
  7. No5id3Fried
    42
    7
    Sep 13, 2010
    Sacramento Ca
    do ineed a lawyer to fight it?the way they tested it was have me drive forward and apply the brakes.
  8. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    You admitted they were out of adjustment. Truckers get tickets if their brakes aren't adjusted properly. Not saying you. but trailers like yours are one of the most neglected pieces of equipment on the road. Simply because construction companies are not in the transportation business. Inspections are minimal and things usually don't get fixed until they break completely. That said, he was probably teaching you a lesson?
  9. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    When I pull a load on my trailer I use the electric brake and engage it to see if the trailer brakes will stop the trailer/car. I do this about 5mph. If not then I adjust the gain till it slows down the combo, but not locking up the brakes.
    Mark
  10. dieselbear
    dieselbear Road Train Member
    1,798
    2,800
    Oct 18, 2008
    My guess is exactly what scalemaster stated. What regulation does the inspection report cite? 393.43 or 393.48? From my experience a trailer like you described would have the breakaway device activated to see if the emergency brakes work. Dead battery or no connection to the battery is the most common thing I find that render the emergency brakes useless. As for running by, be sure what that sign(s) say about who needs to pull in. Guys that run by generally get a lot of attention.
  11. Okieron
    Okieron Crusty Okie
    1,641
    1,024
    Dec 23, 2009
    muskogee, ok
    I believe in Ca. if its a one ton and over with a certain weight ya gotta stop, but its been awhile.
