No headache rack?
Discussion in 'Flatbed Trucking Forum' started by rank, Sep 4, 2021.
  1. rank
    rank Road Train Member
    9,919
    113,510
    Feb 11, 2010
    is it even possible to pull step decks with a 244” wb 379 and 62” bunk? I don’t see room for a headache rack. Not much frame rail space to store chains, binders, 15 straps, flags, 4 banners, strobes. Usually pulling different trailers so trailer storage doesn’t work either. Does anyone do this?
  3. blacklabel
    blacklabel Heavy Load Member
    870
    1,268
    Nov 6, 2011
    MO
    Get you a few big step boxes? Straps can go in side boxes and chains in step boxes? I don't like a headache rack so I don't see a problem
    rank and singlescrewshaker Thank this.
  4. beastr123
    beastr123 Road Train Member
    2,951
    24,205
    Jan 2, 2014
    Moose Jaw SK CAN
    There are hundreds of 244" 379 with 63" bunks pulling steps/flats out of western Canada where 244"WB was (and I think still is) the maximum WB allowed. It is crowded behind the bunk but by mounting the rack close to the bunk wall (2 to 3") and using a 8" or 10" deep cabinet you can stay inside the wings/air-foils and you will find room for a set of narrow steps for access.
    A legless frame mount helps a lot.
    alds, Bean Jr., rank and 1 other person Thank this.
  5. jamespmack
    216,565
    225 with a 48" bunk and a 30" king pin is cutting mustard.
  6. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    Get a step with a 18 or 24” deep king pin.
    18” inch kp is like having a 262” wheel base.
  7. rank
    9,919
    113,510
    Feb 11, 2010
    Hmmm...244” is/was a rule here too. I don’t recall seeing too many.....maybe some short hood Petes.
    The truck pictured is 253” with one of the skinniest headache racks I’ve come across. The frame rail step is 18”. Taking 11” out of the wb allows for only a 7” wide step box. About the width of my boot. imagining that truck with a 244” conjures up images of a asphalt snack every time I climb down from the catwalk
  8. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Or remove 1 fuel tank and put a massive box on 1 side.
    PoleCrusher and Brettj3876 Thank this.
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,060
    Nov 18, 2014
    Land of local
    The place my dad was leased to didn't do too much flatbed but they had some. He ended up doing this with a 218wb. Catwalk box was for chains/binders then a 2ft box on the drivers side and a 1ft on the pass side. You probably have about the same amount of room @rank
    Wasn't the most organized but it sufficed for what it was. The box sat nicely between the frame rails
  10. rank
    9,919
    113,510
    Feb 11, 2010
    I’m getting by OK with my 253” wb but there’s a 244” long hood that’s caught my eye. Just can’t make sense of it for pulling open decks though.
  11. staceydude
    staceydude Road Train Member
    1,150
    5,029
    Apr 3, 2020
    what year is your truck? I like it!
    BackwoodsGA, rank and PoleCrusher Thank this.
