No heat in Cab
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by das6195, Jan 22, 2019.
  1. das6195
    das6195 Bobtail Member
    2013 KW680 no heat in cab, but heat blow in sleeper. I've check the hoses going into fire wall and they are warm. What else should I check?
  3. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    The valve that lets the water in.
  4. das6195
    I have a PACCAR engine and I don not see any valve to let water in.
  5. xsetra
    xsetra Road Train Member
    5,198
    7,148
    Aug 21, 2011
    Is your heater/defroster blowing air?Does the fan speed work?
    As said above, if your fan works, check your coolant hoses from radiator and from motor.
    Most trucks have two hoses going to each heater. I have a freighliner. Supply and return to the bunk heater, same for your dash heater.
    My valves are just single lever handles that turn 90°, not handles like on a water faucet for a hose on your house.
    Make sure all 4 are turned on. Usually when the handle is parallel with the hose, it's turned on.
    Good luck
  6. A gear per tire
    A gear per tire Bobtail Member
    40
    10
    Jan 26, 2019
    It could also be an actuator that changes from cold to heat not working when switching. Have you heard a clicking noise from inside the dash at all?
