no info on the information display
Discussion in 'Freightliner Forum' started by murat, Apr 1, 2015.
  1. murat
    murat Light Load Member
    217
    123
    Jul 21, 2009
    nebraska
    I have just purchased a 1999 Freightliner Century,I get it home and start going through it and I can't get the information display to work,like the odometer or scan readings,the system is working because the indicators light up,like turn signals and engine and low air lights when you turn the key on.I know the previous owner read the milage off of it when I test drove it.I cant find any info on it on web sites as far as having to turn it on ,it seems it should be always on,am I missing somthing?
  3. mhyn
    mhyn Road Train Member
    4,255
    4,515
    Dec 29, 2008
    Northridge, CA
    if your instrument cluster working and only the display is not working then you have burnt display. it happened with my trucks twice. the display is expensive in the dealer. you can find it cheaper in junkyards.
    murat Thanks this.
  4. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    I might have one or two. If interested let me know. I will take a look tomorrow. If I do I will give you good price on it. I can run VIN and see if they match.
    murat Thanks this.
  5. murat
    217
    123
    Jul 21, 2009
    nebraska
    Ok thanks,I called the previous owner and he said he thought his son had turned it off,or for me to check the fuses,he's not very tech savoy.I really need to have the odometer working.
  6. murat
    217
    123
    Jul 21, 2009
    nebraska
    ok here is the vin #1FUYSSEB7XL9&&043
  7. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    I will see what I have tomorrow. I did not get your post until I was home. Late day. Electrical issues on a truck plus end of the month paper work.
  8. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    Are the last 6 numbers of your VIN 977043?
  9. murat
    217
    123
    Jul 21, 2009
    nebraska
    Opps ! can't believe I did that, yes 977043.
  10. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    It will be Wednesday before I am back at work. Will let you know then.
  11. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
