No lights 96 peterbilt 378
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by killalol, Aug 2, 2022.
  1. killalol
    killalol Bobtail Member
    15
    4
    Apr 15, 2022
    Hello,
    So past week I have no brake lights. Or turn signals/hazards.
    The turn signals and hazards turn on but they do not flash .
    I have change the fuse but it still turns on but does not flash. I have also changed the turn signal switch but it doesn’t nothing.
    also reverse lights probably work half the time .
  3. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    did you replace the flasher? did you check all your bulbs?
  4. lester
    2,956
    8,082
    Jan 2, 2012
    NW, Iowa
    Try unplugging your trailer cord and see if everything on the truck works or vice-versa. Narrow down the problem.
  5. killalol
    15
    4
    Apr 15, 2022
    Yes replaced flasher, and bulbs.
    Is there a flasher/hazard relay?
    there was only a 25 Amp fuse in the fuse box
  6. killalol
    15
    4
    Apr 15, 2022
    Ok I replaced it with another flasher and it worked now? Weird
    Oxbow Thanks this.
