No power to A/C compressor
Discussion in 'Volvo Forum' started by Meagan, Aug 28, 2012.
  1. Meagan
    Meagan Bobtail Member
    8
    Fuses look good, light comes on when A/C button is pressed, when I unhook pressure switch, I get a climate control maintenance fault so I assume that switch is working and I have proper pressure.
    Any thoughts?
    Thanks.
  3. bender
    bender Road Train Member
    2,105
    1,361
    Jul 20, 2010
    Don't Kid Yourself
    Check for B+ current and B- ground at clutch coil with switch in on position. What truck?
  4. beltrans
    beltrans Medium Load Member
    441
    101
    Nov 26, 2008
    spokane wa
    Can be ANYTHING.....................We all know what truck you drive , year , engine...You provided lots of info here....:biggrin_2554: Sorry.
  5. PST
    PST Light Load Member
    125
    53
    Sep 7, 2009
    USA
    Maybe fan clutch switch.
  6. Meagan
    8
    this is on an 06 with D 12 volvo
  7. mech erv
    mech erv Bobtail Member
    Aug 29, 2012
    If you have good pressure and everything else checks out good big common problem with these things changed tons..... change the low pressure switch should be just above the air filter above under the hood cowling along the firewall on the fatter low pressure line the sensors only 90 bucks start there
    Meagan Thanks this.
