No pressure build
Discussion in 'Questions From New Drivers' started by Enrique95, Jun 6, 2025.
  1. Enrique95
    Enrique95 Bobtail Member
    12
    7
    Jun 6, 2025
    Freightliner cascadia evolution 2016
    Hey guys I can’t seem to find the problem with my Freightliner , my psi dropped to 40-60 I searched for a leak but can’t seem to find one, governor is new, air tanks emptied out , now my airbags are deflated I don’t feel pressure going to airbag lines , any help suggestions?
    77fib77 and nextgentrucker Thank this.
  3. Ridgeline
    22,721
    123,347
    You didn't mention the engine.
    I had a problem with a couple of trucks using a 'direct replacement' governor, they were not a direct replacement, one line had to be switched.
    Enrique95 Thanks this.
  4. Concorde
    Concorde Road Train Member
    5,482
    19,450
    Jun 29, 2016
    West Melbourne Florida
    With the engine running is your compressor engaged and pumping air?
    If the compressor isn’t kicking on it will probably be your unloader valve.
    I’m definitely not a mechanic by any means but it sounds similar to what I’ve gone through before.
    77fib77, Enrique95 and nextgentrucker Thank this.
  5. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,548
    2,702
    Jan 7, 2023
    Bad governor, or a worn-out compressor comes to mind...
    77fib77 and Enrique95 Thank this.
  6. Enrique95
    12
    7
    Jun 6, 2025
    Thank you guys for response in the end I checked every single one of your suggestions and it turned out to be the air hose that is connected to the compressor, tho u couldn’t see it because of the. 90 fitting and being tucked underneath the cab and between the frame itself . Thank you guys
    kemosabi49, wulfman75 and Concorde Thank this.
