No pressure in radiator
Discussion in 'Trucks [ Eighteen Wheelers ]' started by jjtrucking, Dec 17, 2013.
  1. jjtrucking
    jjtrucking Bobtail Member
    27
    I have a 60 series detriot can't get no pressure in radiator losing water but can't find the leak
  3. Chip S
    Chip S Light Load Member
    200
    104
    May 27, 2013
    Texas
    Pressure test your coolant cap, should hold 15 psi
  4. jjtrucking
    27
    that what I was thinking could it be blowing the water out the overflow going down the road because it dont have no pressure on the radiator
  5. windsmith
    windsmith Road Train Member
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Just change the cap, it's cheap. My series 60 never built much pressure either.
    Leak - EGR?
  6. jjtrucking
    27
    no it not an egr motor the main thing I can't find were the water is going we done had the head reworked and a new head gasket but on but it still uses water and has no pressure in the radiator
  7. wore out
    wore out Numbered Classic
    17,327
    215,205
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I have seen detroit compressors put a little antifreeze in oil pan and air tanks at same time. But that is discovered pretty quick. I would lean more toward cap or if trans has coolant running thru it the rubber hose gets brittle and is hard to see leaking. They also like to run below the cap a little, they will get rid of what they don't want,
  8. jjtrucking
    27
    I'm going to buy a new cap tomorrow and see if that helps this has been going on for awhile but it got gradually worst overtime
  9. windsmith
    7,296
    6,032
    Sep 2, 2011
    NEPA
    Have the oil analyzed at your next service interval. The sodium level will determine whether the leak is internal or external.
    jjtrucking Thanks this.
  10. jjtrucking
    27
    I found were the water going it going out the overflow tube on the radiator going down the road i'm going to get a new cap today and see if that helps
