No signal light on right side
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Craig_2815, Sep 12, 2020.
  1. Craig_2815
    Craig_2815 Bobtail Member
    I've a peterbilt 379 that dont have signal light r flasher working on right side. And brake light dont work on right. Good on left and marker light and tail light work on both side
  3. kemosabi49
    10,980
    47,926
    Jan 13, 2013
    SW Arkansas
    Tractor only or both tractor and trailer?
  4. Craig_2815
    Tractor only i have my trailer unplug
  5. AModelCat
    164,921
  6. Craig_2815
    No i ck all of them
  7. 062
    062 Road Train Member
    6,333
    33,973
    Oct 20, 2013
    If it’s only the right rear that’s not working, then I would suspect that the plug or wires leading to it are the problem.
  8. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Is it bulb type? Or led plug and play unit?. Could also be the contacts in the bulb socket if lts bulb. Or did someone rewire for a different than stock set up? ( the old wire spaghetti kind)I replace my tail lights with led units that use the same plug as stock. Just mount and plug in. Or could well be something else wrong.
  9. 5K trucker
    5K trucker Bobtail Member
    13
    4
    Sep 19, 2020
    Hi,Craig,you have right side positive wiring touching your grounds wire,that is not letting flasher work on right,5k
